4l60e to 6.0
Old Nov 1, 2021 | 12:23 PM
Clint Cochrane's Avatar
Default 4l60e to 6.0
I have been doing some reading on this swap, but I still not sure if this will even work or if I should give up.
I have a 2004 4L60E that I want to mate with my L96. I am struggling to find parts that will make this work. I know the electrical issue is the big one so I am going to get a Holley Terminator X kit to solve that issue, but what about the physical connection? Do I need a different flexplate or torque converter? What about shift linkage?
Old Nov 1, 2021 | 07:55 PM
B52bombardier1's Avatar
Shift linkage is easy. Lokar makes a universal shift linkage for a column shift or a console shift. Some bending of the shift rod is required to get around the firewall for my column shift so don't cut off too much all at once - cut only a little at a time. Measure many, cut only a few times. Climb under and out from your vehicle . . . . many times.
The ATSG guide series of documents dedicated to the 4L60E can answer your other questions with certainty.
Rick
