Rubber on Knock Sensor Bolt
Old Aug 13, 2024 | 02:03 PM
rpol78's Avatar
Default Rubber on Knock Sensor Bolt
What's the purpose of the rubber on the Gen IV knock sensor bolt? See the pic.
I need to use a button head bolt on the driver's side to help it clear the oil line going to the cooler. I tried to roll it off of the bolt but it just breaks up.
Old Aug 13, 2024 | 07:25 PM
the_merv's Avatar
Maybe a sealant for when it's installed no moisture gets into the threads, or something from packaging.
Old Aug 14, 2024 | 07:46 AM
rpol78's Avatar
Since the knock sensor is a piezoelectric device and detects through vibration, I thought just maybe it was to prevent the sensor from picking up a false reading from the sensor tapping against the bolt. If that's the case I figured I could put a little string caulk or tape wrap on the bolt.
Old Aug 14, 2024 | 10:45 AM
Guy with a Chevy's Avatar
I am sure the design is meant to be rigid so that it induces the same vibrations that come from the engine, no dampening needed. I am sure most mechanics do not apply anything to the bolts that hold these.
Old Aug 14, 2024 | 12:24 PM
rpol78's Avatar
So the question remains as to why GM went to the time and expense of applying the substance to the bolts that come with the sensor. Surely there must have been a reason.
Old Aug 14, 2024 | 07:19 PM
91 Z28's Avatar
Is it really bothering you that much?? Bolt them on and go. I got the same sensors and my bolts didn't come with that stuff on them.
Old Aug 15, 2024 | 07:13 AM
grubinski's Avatar
Since his *did* come with the rubber on it, he asked a legitimate question. With the added information you provided, he now knows it will probably work.
I appreciate people who don’t just send it when faced with something they don’t understand. Details matter.
Old Aug 15, 2024 | 08:31 AM
Old Buzzard's Avatar
A "lock" to allow the assy line guys to grab a sensor and not have to pick up a bolt.
Old Aug 21, 2024 | 10:48 PM
Just installed an LS9 dry sump pump on a build, and it came with the exact rubber “thingies” on the bolts. The rubber..IMO…just holds the bolts in place during shipping. Or as Old Buzzard suggested, it would make assembly line work faster also, because the bolts are already in place and won’t fall out.
Old Aug 22, 2024 | 05:38 PM
the_merv's Avatar
Yup, why I said my second part about being something from packaging.
