PCV is confusing lol
Old Feb 23, 2026 | 09:15 PM
wannafbody's Avatar
The Dorman 264-969 drivers side valve cover is an improvement over the original fbody dsvc.
Old Feb 24, 2026 | 02:10 PM
01CamaroSSTx's Avatar
Yep, couldn't use the dsvc on the LSX or 370 build because both builds have offset rocker arms on the intake valves.
Old Feb 24, 2026 | 06:33 PM
wannafbody's Avatar
Aren't the stock LS3 valve covers the same as LS1 and 5.3 valve covers? Are they taller?
Old Feb 24, 2026 | 06:50 PM
No the baffling is different.
Old Feb 25, 2026 | 07:59 AM
Double06's Avatar
Spanks has the LS9 cover (taller cover) which have the same LS3 baffling pan but has more volume with the bumps to slow the air down I would also guess that the bumps act like a chambered muffler and knock the oil particles out of the air and back into the engine. They probably had some GM engineer do a plexiglass valve cover to study this situation and this is what they came up with. Why would you put bumps there in first place - they have a reason.
