L92 / L76 Intake Photos
I pulled these images off of the ebay ad that was floating around, since these are the only actual photos I've seen of this intake. For those that don't know, this is the intake manifold that will work on the new L92 GM heads, which are found on the '07 Escalade. The port design is very similar to the LS7 head, but in a slightly different location, so it requires this specific intake manifold.
OK, so there are a few floating around on Ebay.
There has to be someone that knows who the supplier is. Also on a board that has well informed/connected members, someone should know who is responsible for the slow launch of products to the consumer.
I'm surprised FAST hasn't looked at the interest and already engineered their own compatible design, produced tooling and sold a couple thousand of these.
12590123 L76 Intake
I hear these intakes are coming in from Canada to USA then on to New Zeland. The back orders are currently being filled first and then the end users will be able to get them. Ebay is a little high but it is worth it.
Tony
Tony
Originally Posted by BigBronco
How about send us those intakes because we have a few set of l92's that move some air
these heads and intake are a direct replacement correct.i.e...i can simply remove my stock ones and these will just bolt right up or do i need anything else?
i was going to get new carteck heads but everyone on corvette forums was telling me to wait for these heads and intake cause they flow'd better and were alot cheaper
car is a 2006 vette
also where would i go to get these parts what are the part #'s so i know im getting the right stuff
TIA
car is a 2006 vette
TIA
We are all spoild,
This is an awesome cyllinder head in its own right, better than 90% of aftermarket offerings for other small blocks in the last 5 years.
You have the raised intake runner designed, good valve angles and a good chamber with potential for large valves.
What more can we ask for?
