Ultimate LS7 intake
Old Apr 23, 2007 | 07:39 AM
  #121
Bowtiejoni's Avatar
Could we get stock LS7 with stock manifold vs stock LS7 with wilson manifold. that would tell the story.
Old Apr 23, 2007 | 10:44 AM
  #122
Stang's Bane's Avatar
Originally Posted by LSmonster
E/T 4.0 LS7 heads. F-R-E hydraulic cam and T/B. Wilson billet LS7 intake manifold... @7200 RPM. 100 octane gas. I could probably run it on 91 octane gas but I didn't for this test.
What did the curve look like below ~4K? I know that wasn't the intent of this engine, but I am just wondering...
Old Apr 23, 2007 | 08:19 PM
  #123
LSmonster's Avatar
Both intakes performed the same below 3500... But after that, the billet intake picked up torque and HP. I have both graphs and I'm working on a way to post it.
Old Apr 23, 2007 | 08:21 PM
  #124
LSmonster's Avatar
Sorry... I don't work with production LS7 engines. But I'm sure someone will do that test very soon.
Old Apr 23, 2007 | 08:55 PM
  #125
71CamaroLS1's Avatar
I'm assuming the Wilson billet intake has somewhat shorter effective runner length, with more runner volume - the same strategy used in the Wilson-designed LSX intake - and if so this manifold will aid big cams more than a stock cam.
Old Apr 27, 2007 | 04:31 PM
  #126
xfactor_pitbulls's Avatar
Originally Posted by 2000_SS
i'm getting ready to build a 402 for my SS. i'm just going to buy a pre-assembled shortblock like the LS2 based ones from Texas Speed. i'll bolt on some AFR225s with a healthy cam. i'm still going to drive the car a lot, but i want it to also perform as best it can for what it is.
would that motor benefit greatly from one of these intakes, or would i be better off with a fast, based on your experience? Also, do they handle boost well? i know billet is strong, but the intake is only as strong as its weakest weld. Are they welded by hand or by machine? i don't know that i'll even run a boosted setup, but it it possible, so i'm just curious at this point. thanks
I was thumbing through the thread and noticed your post. Also looked at your profile, you are a welder and ask a question about them being welded by hand or machine? Look at the bead across the front of the plenum. Whether that is by hand or machine, I would have to assume by hand, that weld quality is more than enough to hold the vaccum or even boost of any of the LSX setups. I have built some CMA low volume pressure vessels with flat walls and they hold 100 psi easy with a 1/4" fillet.
Old May 8, 2007 | 06:25 PM
  #127
hardtop ss's Avatar
Any new news on the dyno test.
Old May 8, 2007 | 06:35 PM
  #128
Louis's Avatar
They are all hand welded, I have one forsale if anyone is interested.
Old May 9, 2007 | 07:23 AM
  #129
RUQWIKR's Avatar
Email sent...
Old May 16, 2007 | 08:35 PM
  #130
So has anybody else tested this intake on an LS7 head motor? Are the lack of results posted due to price, no availability of parts to test, or just unwillingness to post disappointing results?
Old May 17, 2007 | 10:56 AM
  #131
Nasty N8's Avatar
I just tested a billet LS7 intake on a 402" engine and it gained 17 HP over a stock LS7 intake manifold... It gained 10 lbs of torque too. My T/B added another 3 HP and 3 ft/lbs of torque for a total of 620 HP on a Super Flow 901 engine dyno. Both intakes performed the same below 3500... But after that, the billet intake picked up torque and HP.
Just waiting for Wilson to get us more of them. Stock intake takes a dive at 64-6500 this one keeps going we saw 7300 and was still climbing. It is a definate advantage for a motor spinning over 6500rpm
Nate
Old May 23, 2007 | 09:46 AM
  #132
427's Avatar
427
We have run this intake finally, and the results are +15hp at the tire at peak. The factory intake made 505.9@7100rpm and the Wilson made 520.6@7000rpm. The engine carry's rpm well to 7500 and should be a blast to drive on a road course. The intakes stay equal below 3800, then the wilson starts to gain slowly to the 15hp peak gain. This engine is a 427 with ETP heads set up for street/track day type use with a solid roller cam.
Kurt
Old May 23, 2007 | 04:40 PM
  #133
2000_SS's Avatar
nice #'s! this intake is a little extreme for my needs right now, but if i go all out i might spring for one...
Old May 24, 2007 | 02:12 PM
  #134
Nice gains, but it was like I thought. A huge improvement on cathedral port stuff and not quite so much on ls7 stuff. I am sure the hotter the combo beneath it though, the better the gains.
Old May 24, 2007 | 02:22 PM
  #135
Bowtiejoni's Avatar
Thank you Kurt!!
15 hp is nice but with the price of wilson manifold ? Not mayby good idea on stock engine??
Old May 24, 2007 | 02:32 PM
  #136
Nasty N8's Avatar
Deffinatly not for a stock motor. The more power the more gains you will see.
Nate
Old May 24, 2007 | 03:39 PM
  #137
Quickin's Avatar
Nate
Hi Nate,
I'm talking with Allan Futral right now about a cam for my set-up. He asked me if I knew the runner length of this Wilson intake. I'm pretty certain I'll be going with it and ordering it tomorrow or next week through my builder.
Can you PM me with details of the intake.
Thanks.
Old May 24, 2007 | 11:49 PM
  #138
LSmonster's Avatar
Kurt
Interesting... Looks like the gains were these same as my 402" engine...
I'll be testing one on a 443" engine in two or three weeks, and I'll post the results. And I'm testing the LS1 style tomorrow night. I'll let you guys know how that turns out.
Old May 25, 2007 | 11:00 AM
  #139
Black Sunshine/ 00SS's Avatar
Subscribing.. I'm interested in what it will do on a 402, AFR225, big cam car..
Old May 25, 2007 | 11:04 AM
  #140
More than likely, the gains would be much better than this one. I wouldn't be surprised to see more like 35-40 or more. The higher you spin it the better the gains should be.
