Ultimate LS7 intake
Old Jan 25, 2007 | 10:40 PM
  #81
Stang's Bane's Avatar
Originally Posted by Louis
I have a stock LS7 and a 570whp LS7, and a 700 whp LS7. Ill test them on all 3 with in the next week-2.
A little more info please
Old Jan 26, 2007 | 01:09 AM
  #82
brausch's Avatar
Originally Posted by LSmonster
I have both intakes. Wilson LS7 billet and factory LS7. I'll have dyno results in a month or so. I've also used 3 of the Willson billet intakes, LS1 style on 402-427 engines and they are light years ahead of the plastic intakes... Worth every penny!
What were your gains on the LS1 style billet over a LS6 or FAST 90/90 on a 427? Do you have any dyno sheets?
Bernd
Old Jan 26, 2007 | 08:07 PM
  #83
tlaselva's Avatar
Since LPE now makes a 100mm MAF, it goes to reason that the next restriction on the path of the air to the intake is the TB. Does anyone make a compatable LSx TB bigger than 90mm, and if so, does Wilson make that intake to take the larger TB?
I've heard several times that N/A power is restricted by the 90mm intake components.
Old Jan 26, 2007 | 08:38 PM
  #84
325trooper's Avatar
I've thought about that, too. Never heard of a LS* engine with a 100mm, but they are made.
Old Jan 27, 2007 | 05:21 AM
  #85
Bowtiejoni's Avatar
If you know anything about wilson, they never produce anything that isnt top notch. They are having CNC issues, but Im looking at having one here with in 2 weeks. The day the UPS guy brings it, its going on 4 cars. Im paying for my R&D so YOU guys benefit. Like the LS7 comparo for the LS2s, we gained nothing but valuable info.
Louis
I think you are doing great service for all of us.I highly appreciate it and if i ever need something for my current LS6 or future engine will ask you too.
What about heat issues? Stock LS7 intake dont store much heat because it dont have much of mass and its plastic. But wilson manifold is sheetmetal and billet aluminium wich stores heat ??
Old Jan 27, 2007 | 06:51 AM
  #86
Solid346's Avatar
what is that TB , it not comaptible with the LS sensors , right?
Old Jan 27, 2007 | 06:55 AM
  #87
325trooper's Avatar
It's made in Thailand, of all places. They have tps fittings that work with japanese engines, and Fords. But it could be made to work with GM's. If you Google "100mm throttlebody" you can find it.
Old Jan 27, 2007 | 03:53 PM
  #88
slt200mph's Avatar
I am Looking forward to the results of these test
Old Jan 28, 2007 | 12:28 AM
  #89
DanZ28's Avatar
LS1Joe is running a 104mm TB on a Beck sheet metal, so they can be had.
Old Jan 28, 2007 | 06:25 PM
  #90
LSmonster's Avatar
Bernd
I don't have any Dyno sheets, but typical gains with the right parts that allow you to take advantage of the billet intake are around 75 HP over the F/X intake. The plastic intakes are flat @ around 6000/6500 RPM. <(My applications) The billet intakes will make peak HP with the same cam/heads @ 7200/7400 RPM... So for my customers the extra 75HP for $3000.00 is worth it to them... Others might not agree.
I have the luxury of tying these intakes on several different styles of engines and head combinations. 402/427/443 with ET heads, ALL PRO heads and Elderbrock Pro Port heads so I see what these intakes like. The LS engine is not a "small block chevy"... If you treat it like one you you'll get nowhere near what you're looking for out of it.
JMHO
Old Feb 3, 2007 | 11:42 AM
  #91
BlackHawk T/A's Avatar
Originally Posted by Katech
I will be A-B testing this with a stock LS7 manifold at some point in the next month.
Still planning on this?
Old Feb 4, 2007 | 11:37 AM
  #92
Katech_Jason's Avatar
LS1TECH Sponsor
Yes, but there have been parts delays out of our control.
Old Feb 4, 2007 | 11:43 PM
  #93
LSxChevelle's Avatar
Originally Posted by John B
You 'da man Louis! I already have my name on a waiting list for this manifold! Once I hear you give it the thumbs up, it's bombs away!
So are you ever going to put a cage in that car and run some 10's w/ the power you'll have??
Old Mar 13, 2007 | 03:57 PM
  #94
Any results from this thing yet????
Old Mar 13, 2007 | 04:41 PM
  #95
tlaselva's Avatar
Keep on noticing posts of people proclaiming the virtues of sheet metal intakes, and that a dyno comparison between them and a composite intake will be done.
And again, weeks/months later nothing.
I'm almost convinced these sheet metal intakes are not what people claim them to be.
Old Mar 25, 2007 | 01:24 PM
  #96
ls1408cp's Avatar
any updates?
Old Mar 27, 2007 | 03:50 PM
  #97
ls1408cp's Avatar
ttt I will buy one if they work
Old Mar 27, 2007 | 04:11 PM
  #98
427's Avatar
427
I think some people are just waiting for the intakes to be done.
Kurt
Old Mar 27, 2007 | 04:13 PM
  #99
Nasty N8's Avatar
Sorry no dyno # as of yet. But they are certianly far better than most intakes for the LS7.
Nate
Old Mar 27, 2007 | 04:40 PM
  #100
WKMCD's Avatar
Nate
If Wilson makes one for the L92's at a decent price point with runners in the 7-8 inch range they will sell more than they can possibly make.
