Ultimate LS7 intake
Old Jan 21, 2007 | 02:15 AM
  #41
GrannySShifting's Avatar
Originally Posted by JL ws-6
I'd be curious to see a test of the ls1 manafold, and a fast, to see what the 2 compare out like. I dunno if dropping 3 G's on an intake would be worth it.. it would have to make at least 30 more Hp then the fast for a good part of the RPM range on a 400+ ci motor for me to even consider it honestly.. but still be an intresting test.
The ls7 type, vs the actual ls7 intake should be intresting as well.
Worth the money? no wayy Thats would be a $100/hp mod. Guys have a hard time justifying a FAST 90 for 30 hp, and thats $40/hp
Old Jan 21, 2007 | 06:38 AM
  #42
JL ws-6's Avatar
Race your car!
Like I said.. I would have a real hard time justifying the $ that costs be worth while... even if it is 30 hp over the fast and I sell my fast for say 800, I'd still have a real hard time swallowing that.
Old Jan 21, 2007 | 09:45 PM
  #43
Right, I wouldnt be able to justify that either
Old Jan 22, 2007 | 12:12 PM
  #44
silverbeast's Avatar
that thing is sweet! ....... but 3 grand is to damn much. If it was 2 grand they would sell more than they could make,imho.
Old Jan 22, 2007 | 12:47 PM
  #45
Beast96Z's Avatar
There comes a time when you have to stop looking at the $/hp. If your at a point were you need the additional intake charge, you have to get past the cost. It's just one of those things that you should start saving for, because it is not hard to overcome a composite LS intake.
Old Jan 22, 2007 | 01:21 PM
  #46
Patrick G's Avatar
LS1 Tech Administrator
Until a more affordable alternative comes out, that is a very true statement.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 23, 2007 | 06:56 AM
  #47
litle88's Avatar
Default LS7 intake
A friend of mine is selling his stock LS7 intake to me. I have a 2001 stocker, will it fit and will I see any improvements? I think he bought one of those bling intakes. Any hepl will be greatly appreciated.
Old Jan 23, 2007 | 07:10 AM
  #48
Patrick G's Avatar
A rectangular port LS7 manifold will not fit a cathedral port LS1/LS6 style cylinder head. Different port size and shape.
__________________
Old Jan 23, 2007 | 02:16 PM
  #49
Nasty N8's Avatar
LS1 version of this intake is worth about 70-75 OVER an LSX intake on a built 402 NA motor. Where stock style intakes loose momentum at 6500 or so RPM this thing is just getting warmed up. Couple of dynoed motors spinning to 7500 the power just kept climbing never running out of steam. The LS7 should be easily that good Will post results on the LS7 soon.
Nate
Old Jan 23, 2007 | 02:23 PM
  #50
pianoprodigy's Avatar
Nate
Dang...that's badass
I know what I just added to my list for my future NA monster...
Do you have a dyno graph comparing the two by chance? Is it 75 hp throughout the curve or it more of a peak gain?
Old Jan 23, 2007 | 06:18 PM
  #51
Nate have you done back to back tests with that, or just Wilsons info?
Old Jan 23, 2007 | 06:25 PM
  #52
Nasty N8's Avatar
It is a good gain across the board but more of the bulk is high end of the RPM range.
Not me personally but Forester has done alot of testing as he wants the absolute best for his motors. These are all big dollar high revving monster motors. Like I said this LS7 will be tested on a pump gas 443ci ERL block motor shooting for over 700hp.
Nate
Old Jan 23, 2007 | 07:13 PM
  #53
JL ws-6's Avatar
Race your car!
o.k., now if the cathedral version makes 70 hp over a fast 90.. he $ is alot easier to slwallow, but I want to know.. if that was on a 402 ci motor, what heads/cam/compression/exhaust was beign run when this test was done?
If I could sell my fast for 800 and buy one of these for 3000 with the rails say, and gain 70 hp that makes it a little better.. but I somehow doubt I'm running a hot enough setup, with a set of et 240 heads, 13 to 1 compression, mid 240's cam and a 1 3/4 header into a catted street legal exhaust to see that type of gain.
FWIW, my car made 443 rw thru a th400, 12 bolt, and a converter that flashes to 6000, so it's not a dyno queen driveline by any means, thru an M6 it would probably be about 500 rw maybe a touch more (figuring about 70 hp differnence from a th400 and loose converter to an M6) so that's about 590 to 610 at the crank.
I would like to see the results though, whatthey got the 70 hp on, and some details on that test.
Old Jan 23, 2007 | 07:44 PM
  #54
xfactor_pitbulls's Avatar
Does your car run? I have seen posts with your current sig forever and no results. Whats the deal?
Old Jan 23, 2007 | 08:03 PM
  #55
beardWS6's Avatar
I`m curious for one on my 408 in sig. I also have ET 245`s with a new cam around 250 255 647 646 112( I believe) with motor in sig. I have ported LSX90 set-up also. I might be interested in a wilson, but I don`t spin over 6500rpms. Would it benefit me? I`m only spraying a 200 shot.
And like he ask, Beast how is yours coming along? Thanks!
Old Jan 23, 2007 | 08:11 PM
  #56
Reckless's Avatar
Super Moderator
Just an FYI, the intake does not come with the fuel rails, they cost extra. We ordered one today for the red Camaro we are doing.
Since we already ran the engine on the engine dyno and put it into the car, we plan on running the GM LS7 intake for breaking in the clutch. We will then chassis dyno the car with the GM LS7 intake, and then bolt on the Wilson LS7 piece and chassis dyno the car for fine tuning.
We would have rather done the testing on the engine dyno, but we have already passed that phase of the build.
PS - Nate...I promise I am not hi-jacking your thread
Old Jan 23, 2007 | 08:21 PM
  #57
Beast96Z's Avatar
Dosen't really have anything to do with the thread, but no, it dosen't. Major problem right now is getting my K-member that I've been waiting on for over 8 weeks now. Money and time have also been a major concern over the past few months. OT cuts down in the winter months and checks get thin. I could go on, but if you need more info, use PM. This is a bit .
Old Jan 23, 2007 | 08:45 PM
  #58
Nasty N8's Avatar
For one you should really spin it higher those heads will love it. And yes I think your setup especially with the nitrous would benifit from it.
Nate
Old Jan 23, 2007 | 09:27 PM
  #59
Off topic............honestly big freaking deal. Not like every thread doesnt get derailed by 25% BS threads. I find it alittle to have a bit of humor that you preach about things you have bought and not had one result from. That is why I ask, and there to me is relevance when you are remarking about applicable intake choices.
Old Jan 23, 2007 | 09:31 PM
  #60
LS1LT1CAM's Avatar
Do not need boost to use an intake like this it will work on an all out large qube motor. This intake is going on a ERL block 443" engine with ET performance LS7 heads Built by F-R-E, shooting for 700 HP on pump gas... Dyno graph will follow. We carry alot of his billet parts. Like LS2 valley covers valve covers and manual tensioner pulleys.
Nate
HOW MUCH FOR THE VALVE COVERS?
