L76 intake package-why are the injctors to SHORT>! HELP
Old Mar 19, 2007 | 02:54 PM
SVT THIS's Avatar
Default L76 intake package-why are the injctors to SHORT>! HELP
Wow, ok, all the problems earlier have been solved. Now, the 40# injectors that come with the L76 intake manifold/fuel rail/tb are not going to fit. They are about 1/2 an inch to short. They are shorter than the stock 28lb'ers rom the LS1.
What should I do? Do I use the stock fuel rail, bend some stuff, anything? I am ready to get this thing going.
Old Mar 19, 2007 | 04:14 PM
White_Hawk's Avatar
You need an LS2 rail. Didn't the manifold come assembled with a rail? I am pretty sure it won't fit if you use an LS1 rail with shorty injectors.
-Geoff
Old Mar 19, 2007 | 05:16 PM
Dragaholic's Avatar
9 Second Club NA
If you bought the complete package, then you should have the LS2 fuel rails. If you bought the intake separate, then you'll need to purchase a set.
Old Mar 19, 2007 | 05:32 PM
RGKSR's Avatar
Default I'll take pictures
If you need pictures of the complete setup, send me a PM. I can post them but I'd be happy to mail them.
Bob K.
Old Mar 19, 2007 | 05:36 PM
WKMCD's Avatar
I put a FAST/Aeromotive system on my L76 intake.
Old Mar 19, 2007 | 06:04 PM
Darren P's Avatar
I want to know where those valve covers came from
Old Mar 19, 2007 | 06:33 PM
fenix999's Avatar
nice, me tooooooooooooo looks sweet, looks fasssst
Old Mar 19, 2007 | 07:26 PM
Dragaholic's Avatar
9 Second Club NA
I believe they're the GMPP valve covers and he painted them.
Old Mar 19, 2007 | 08:13 PM
Darren P's Avatar
Thanks
does anyone have a P/N
Old Mar 19, 2007 | 08:21 PM
Dragaholic's Avatar
9 Second Club NA
https://ls1tech.com/forums/showpost....4&postcount=15
Old Mar 19, 2007 | 09:54 PM
Darren P's Avatar
Thank you
Old Mar 19, 2007 | 10:50 PM
jtl12419's Avatar
Back to your injector question. The stock LS2/L76/LS7 injectors are very short and also require the newer electrical connector, they also have fatter tips than the older style injectors. I think they are 39# injectors. You can buy electrical connectors to link these new injectors to an older LS1 system for about $100/set.
If you want to use non-stock, older style injectors: You can run the LS2 rail or other aftermarket rails designed for LS2, but you still will have to space for the increased injector height. The other consideration is choosing the correct O-ring for the thinner tips of of the older style injectors.
I am using the Bosch Ford racing 42# green tops. I found that 3/4" long brass spacers at the fuel rail mounts works well, not perfect but I think well enough. You obviously need longer mounting bolts.
Next challenge will be how to mount the TB cable to intake. I have not found a good solution yet. The bracket I bought recently from one of the posters on this list does not fit.
My LS2/L92+L76 engine is physically about 95% finished after many parts/supply obstacles. I am waiting on springs and rockers currently.
Good luck on your build.
Old Mar 19, 2007 | 11:28 PM
Quik's Avatar
i used my ls1 fuel rail with svo injectors ad also had a bracket made thatworks well
i also had to tweak the mounting tabs to line up and use spacers
Old Mar 20, 2007 | 08:04 AM
WKMCD's Avatar
I got the valve covers from SDPC and had them powder coated Candy Apple Red. Coil relocation kit by PHIL99VETTE - aka Phil Thomas.
Old Mar 20, 2007 | 08:35 PM
SVT THIS's Avatar
Well SDPC told my builder that the injectors will work. We got the 40# injectors and rails that come with the L76 intake manifold kit. We didn't relocate the coils, he just bought some different brackets. I'm not exactly what valve covers he used, but he got them to work. Thanks all, hope to get it running by Friday tops.
