Ls7 Maf
Old Mar 27, 2007 | 12:08 PM
gojo's Avatar
Default Ls7 Maf
What MM is the LS7 MAF?
Old Mar 27, 2007 | 12:16 PM
Quik's Avatar
last i checked it was a card
Old Mar 27, 2007 | 12:48 PM
sprayjunkie's Avatar
Pretty sure it is just a drop in element in whatever size housing the bellows uses.
Old Mar 27, 2007 | 12:58 PM
gojo's Avatar
Thanks for the information.
That begs the next question. If an LS7 is installed in a C5 will the stock 75mm be a restriction?
Old Mar 27, 2007 | 02:44 PM
ringram's Avatar
Yes Sir
Old Mar 27, 2007 | 06:03 PM
gojo's Avatar
Originally Posted by ringram
Yes Sir
That was short and sweet. You're usually more expansive.
It looks like LPE's 100mm is an easy option.
Joe
Old Mar 27, 2007 | 10:32 PM
Corvettes White's Avatar
What am I missing here? One simple question and three answers from guys with a lot of posts and no simple direct answer the question. A card?, whatever size? and Yes Sir?
I would also like to know the true answer, Can one of you please give an answer in terms of MM?
George
Old Mar 27, 2007 | 11:10 PM
gojo's Avatar
http://forums.corvetteforum.com/show....php?t=1626121
http://www.lingenfelter.com/store/lp..._lpe-4232.html
After getting the answers posted I did more searching.
Check out the links and you'll see that the sensor can be put into different size tubes, as was pointed out.
Old Mar 28, 2007 | 01:14 AM
the_merv's Avatar
I think that 100mm is going in my new Engine..
