L92/L76 Intake Manifold Flow Comparison
Old Jul 19, 2007 | 09:56 PM
  #41
Richard@WCCH's Avatar
Originally Posted by thunder550
I think I answered my own question. Here are the L92 and LS2 truck manifolds together. You can see the difference where the gasket would go.
You're correct. The two intakes are different due to the cathedral vs rectangle port shape. I'm not too sure how much they differ further up into the plenum area, but I don't think it's major.
Richard
Old May 26, 2008 | 12:11 PM
  #42
Blindmelon's Avatar
I am still waiting for the Weiand intake coming out this summer. It is for the L92/LS3 heads. It will come in 2 finishes & is out of composite light weight material. They have part numbers for it already & say this summer. I have a TrailBlazer SS LS2 with L92 heads with forged bottom end & now using truck L92 intake. Truck guys will have to change out water pump to clear the TB (use GTO water pump) pointed toward radiator not up like the truck. Driver side accessory bracket & idler pulleys may have to change but pic's show it tilting up more so maybe the water pump only will do it. They are getting over 28 hp over a L76 or truck they say in testing. Cheap also $550.00 range.
LOL
Old May 26, 2008 | 11:07 PM
  #43
firefighting1101's Avatar
well i have a set of your heads on order richard through HKE and im going to be using the beck sheetmetal L92 intake so hopefully we get some good results.
Old May 27, 2008 | 08:39 AM
  #44
veee8's Avatar
Richard, did you ever get a chance to test the carb intake?
Old Jun 2, 2008 | 01:25 PM
  #45
Red Goat's Avatar
Default info on intakes
Great information Richard, I appreciate your diligence and effort in this research. Whether or not Weiand, FAST, or whoever comes out with a "performance" intake for the L92's, its obvious that GM raised the bar on the factory styled rectanglular cylinder heads at a fraction of the cost of most aftermarket heads. I will run a ported L76 intake w/ my heads ( which are not installed yet) until I see a better product available.
Old Dec 15, 2009 | 07:06 PM
  #46
patooyee's Avatar
Hey guys, I made this to help myself but figured I'd share. Is anyone making anything near the 450 rwhp range with either of these manifolds?
J. J.
Old Dec 15, 2009 | 07:49 PM
  #47
patooyee's Avatar
Richard, I've seen you refer to the L76 manifold as the modern-day single plane manifold and the L92 as the modern day dual-plane. Is that to say that the port velocity in the truck manifold is higher than the car? IE, the truck manifold is the "torquer" manifold and the L76 is the HP manifold? Or that the truck intake is capable of developing more low end torque and the car more high end hp? It could be that I am thinking about it too traditionally???
J. J.
Old Dec 22, 2009 | 12:34 AM
  #48
J. J.
This is a bit of history
Although I am not an intake scientist, here's a brief overview of our perspective on intake systems.
There's much more that goes on in any single or multi cylinder intake manifold than port velocity. With engine speed, in micro seconds air pulsates back and forth due to the valves opening and closing. Within those events sound waves are generated that travel up (and down) the lenghts of the intake (and exhaust) runners creating a "ram tuning" effect. Manifold runner length then has a contibution to make regarding cylinder filling at differing cycling speeds. The "truck style" L92 intakes have a longer runner than the L76 intakes and thus they are capable of generating greater amounts of cylinder filling at lower engine speeds. Search for a program called "Pipe Max". It will give you many answers to the questions regarding torque production vs rpm.
Thanks for sharing your information.
Richard
Old Feb 14, 2010 | 02:57 AM
  #49
kballs's Avatar
Default intakes
Great info!
Old Dec 27, 2011 | 10:05 PM
  #50
my406cid's Avatar
this thread has been dead for a while and there a re plenty of people running the factory trunck intakes. anybody got any rwhp numbers running a truck intake? l92 or cathedral port.im going to run a lingenfelter gt-11 cam with l92 heads ans the l92 intake.wont rev high but will have lots of area under the curve and be a good street and open road car.
Old Mar 30, 2012 | 09:28 PM
  #51
91Z28's Avatar
I'm looking at upgrading from my truck intake because of disappointing dyno numbers after a heads/cam upgrade. I am having a slight vacuum loss at WOT so the engine is obviously starving for air. Just don't know which way to go yet, ported truck intake or maybe a FAST. All the mixed results with FASTs and reports of quality issues and the pain of making it work in a truck make me lean towards the ported L92 intake but I don't know how much they will flow. With the factory truck intake, ported heads, and a 218/226 high lift cam I only put down 396rwhp.
Old May 4, 2012 | 08:54 AM
  #52
G8-4-speed's Avatar
I have done several test on the flow bench porting intakes and throttle bodies bolted to the heads without anything to expect a dyno gain from. The only way I found to increase the airflow was to cut an intake and epoxy a radius to the port entry. Epoxy in the intake isn't something I would trust over a long period of time so you can't use it plus you have to cut apart an intake to get the back runners and it just isn't worth it. So for a while I have sat on the bench not really pushing or recommending intake work because it is usually a "wash" on gaining anything. Now with another car to modify, it seems I revist the same delema of trying to get more from the same drum I have beat to death already. Well, I found it! Hear is the flow results:
Livernois heads with 5 axis valve job and bowl blend with a VMS ported intake bolted flowing thru a ported throttle body:
Lift CFM
.300- 201.0
.400- 248.1
.500- 278.8
.600- 294.1
.700- 302.7
Lift CFM w/ same heads ported and modified intake
.300- 212.3 +12.3
.400- 262.6 +14.5
.500- 294.1 +15.3
.600- 313.5 +19.4
.700- 324.5 +21.8
Lower lift gains are from porting/valve work to the Livernois intake port on the heads. Higher lift gains are mostly the intake .500-.700" The intake has a radius bar installed on either side at the runner entrance. Just thought I would pass this on since I haven't seen anyone post "ported" intake flow numbers. I would guess the main reason is porting the runners doesn't show any gains on the flow bench worth talking about. What the gains are worth on a dyno is anyones guess, but potential is there.
Old May 4, 2012 | 01:56 PM
  #53
1989GTA's Avatar
Soooooo, for clarification what intake and what heads are we talking about. Nice gains by the way.
Old May 4, 2012 | 08:01 PM
  #54
G8-4-speed's Avatar
Standard LS3 style castings. Standard L76 intake. Base test was a Livernois LS3 head with their valve-job and bowl blend and a VMS ported L76 intake bolted on. Next test was with a radius bar installed in the same intake and some cleanup work valve back-cut on the same heads. Same head and intake using the same port, just "before" and "after" results.
