Ls2 402 specs! =)
Old Apr 2, 2007 | 06:20 PM
Bx goat's Avatar
Default Ls2 402 specs! =)
LME built GM LS2 6.0L Block 402 cid 11.0:1
ARP Main studs
ARP Head studs
Eagle 4340 4.0" stroke crank
Wiseco 4.005" Bore pistons L92 VP's 1cc pocket volume
NPR stainless chrome rings
Callies 6.125 H-Beam rods w/ARP 2000 7/16" bolts
GM HV oil pump
Rollmaster double chain
DuraBond cam bearings
Clevite rod & main bearings
Untouched L92/L76 combo w/upgraded valve springs, HS modified oem rockers
Cam specs:
Lobe Seperation 112.2
Intake duration 244.9, Lift .630
Exhaust duration 253.2, Lift .631
Old Apr 2, 2007 | 06:21 PM
Bx goat's Avatar
That's clearance!
Tom at work!
Bx goat's Avatar
Old Apr 2, 2007 | 06:24 PM
Bx goat's Avatar
Question
J&T out in Huntington Long Island is doing all the work. Great guys!
Have a question for you guys though. Will the L76 injectors do the job on this engine or should I invest in some bigger injectors?
Old Apr 2, 2007 | 06:36 PM
the_merv's Avatar
Veteran: Air Force
That Cam is a nice one, should be a monster..was it a custom grind?
Old Apr 2, 2007 | 06:48 PM
marcus769's Avatar
cool pix! Kinda like that exhaust idea minus the empty spot in the exhaust indendation in the back now...
Bx goat's Avatar
I believe it was. Cam Motion =)
Think I should upgrade injectors? lol
Old Apr 2, 2007 | 06:51 PM
Bx goat's Avatar
That's going to be taken care of via.....
Any injector advice? =)
Old Apr 2, 2007 | 08:25 PM
J's99Zrated's Avatar
Sounds like my 402 build:
Eagle 4.00" stroke crankshaft
Scat H-beam 6.125" rods
Diamond -10cc pistons
Arp everything
TSP Texas Giant Camshaft
248/254, .611"/.613" 111LSA <------very similar cams
TEA Stage 2 5.3 Heads
Fast 90/ PTM 90
LT's + ORY + Cutout
Old Apr 2, 2007 | 09:17 PM
FieroBob's Avatar
Ls2 402 specs! =)
ARP Main studs
ARP Head studs
GM HV oil pump
Cam specs:
A question about the cam.
Are the durations listed @ .006", or at .050" of valve lift?
Best of luck with the engine.
I hope it puts a big smile on your face every time you put your right foot down.
Old Apr 2, 2007 | 09:27 PM
Bx goat's Avatar
Question
Arp everything
Fast 90/ PTM 90
LT's + ORY + Cutout
NICE! Do you have pictures of the build or video?
Originally Posted by FieroBob
A question about the cam. Are the durations listed @ .006", or at .050" of valve lift?
Durations listed are at .050"
Thanks for the kind words. I'm still interested in whether or not the L76 injectors will get the job done?
Old Apr 2, 2007 | 11:47 PM
Not yet. The final install gets done over the easter weekend. I will have some then that I can post up for you.
Old Apr 12, 2007 | 01:19 PM
Bx goat's Avatar
Thumbs up Idle video
http://videos.streetfire.net/video/9...090166a97b.htm
Old Apr 12, 2007 | 01:48 PM
RGKSR's Avatar
Default Sounds Great!!!!
Sounds great!! How does it drive????
Bob K.
Old Apr 12, 2007 | 10:10 PM
Bx goat's Avatar
It's got a really safe tune for now. The guys at Vette Dr's do things the old fashioned way. They wanted to put a few miles on it before they put it on the dyno. No numbers yet!
Old Apr 12, 2007 | 11:37 PM
beardWS6's Avatar
Nice set-up!
Old Apr 25, 2007 | 10:51 PM
05mbm's Avatar
That is a sweet setup you have there.
Old Apr 25, 2007 | 10:54 PM
THE_SUPRA's Avatar
that looks killer! get some vids up ASAP!
Old Apr 26, 2007 | 08:05 PM
TrekGTO's Avatar
Are you using the L76 injectors? They are same as LS7 I dont think you will max them out from what I have seen in HPT
I bought complete manifold came with, just made $ sense.
Old Apr 27, 2007 | 11:42 AM
paco loco's Avatar
very nice!
