6LS-2 controller Pro-Data+ so???are?
Old May 4, 2007 | 02:06 PM
paco1112's Avatar
Default 6LS-2 controller Pro-Data soft ware
I just put in a LS364 in a 1967 camaro with a MSD ignition 6LS-2 controller. MSD has included several plug in chips for advance timing control. This controller also has the ability to map a timing advance curve with MSD’s easy-to-use Pro-Data+ so???are via a lap top computer. Does anyone have any experience with this? Is it worth my time to use the so???are or to stick with the plug in chips?
Old May 4, 2007 | 04:05 PM
Vcious04's Avatar
Use the pro-data so???are, VERY easy to use and works like a charm. I would advise disabling the map advance if your are not a fi application. Let me know if you need any detailed info..
Old May 4, 2007 | 05:49 PM
paco1112's Avatar
Sorry about the miss spelling. For whatever reason when I posted the thread the question marks appeared. It should read pro data soft ware. Anyways if you have detailed information I would really appreciate it.
