Fuel Rail Options For L76
Old Aug 2, 2007 | 01:55 PM
Mikey 97Z M6's Avatar
Default Fuel Rail Options For L76
Search function is down,,,,,,,,, again!
So, I'm sort of on the fence about purchasing the L76 manifold complete, or buying a bare manifold. I was wondering if the injector spacing is the same for the L76, and can an aftermarket fuel rail for the LS1's be used on the L76's? Just checking to see if there is anyone with a custom fuel rail setup on the L76 yet. If so, please post up some pics and/or information on your setup.
Thanks,
Mike
Old Aug 2, 2007 | 02:33 PM
ls1290's Avatar
Dumb Ass Vette Moderator
I think you need to use the LS2 style billet rails rather than the LS1/LS6. I am pretty sure the L76 and LS2 have the same mounting points.
Keith
Old Aug 2, 2007 | 03:34 PM
Keith
Thanks, didn't even think about the LS2 style being different from the LS1's. If this is true, then at least there are some options available.
Old Aug 2, 2007 | 06:22 PM
1bigcam's Avatar
yes ls2 is the same as l76 i just did it
Old Aug 3, 2007 | 05:47 AM
WKMCD's Avatar
FAST LS2 rails:
Old Aug 3, 2007 | 11:28 AM
Originally Posted by WKMCD
FAST LS2 rails:
That looks nice!
Old Aug 3, 2007 | 05:03 PM
Oh4GTO's Avatar
Will the LS1 FAST rails work? I have a feeling everyone wil say no.
Old Aug 3, 2007 | 08:51 PM
WKMCD's Avatar
I don't know about everyone else but I'll say it - No!
Old Aug 4, 2007 | 01:58 AM
shovelhead73's Avatar
Old Dominion,
Very nice and detailed. Where did you get the oil neck with breather..... and where did you mount the coil packs..
Old Aug 4, 2007 | 11:07 AM
slt200mph's Avatar
subcribed
Old Aug 4, 2007 | 12:16 PM
WKMCD's Avatar
Originally Posted by shovelhead73
Old Dominion,
Thanks.
On the L92 heads there is a rocker just below the filler hole so I had to make sure the breather was more upright. I went down to the local autozone and stared at the rack until I found 2 pieces I thought would work. The coils were relocated by PHIL99VETTE. The driver's side are behind the inner fender and the passenger side are right of the battery. This is on a C5.
