lq9 questions
i think a whole engine could be done for around 3 grand how u want it.
the iron blocks are good for 1000 hp..your only shooting for what 450rwhp so thats around 600 at the fly wheel.
pick up this months hot rod mag and they have a engine there doing with the l92 heads that makes good power.
for what your doing a eagle rod is fine..pistons i like cp and diamond..if u plain on running juice down the road or are even thinking about it u will have to factor that into build..a n2o piston is alot diff then a n/a piston.the ring lands are moved down because of the more heat u get with juice.
i think there is no real down side of running a n2o piston in a reg engine.the piston will probley be lil heavier and thats because the domes are thicker on them to handle the heat also..
u can go on speedtalk.com and ask over there..there are alot of top engine builders over there.
