MAF for L92 416 stroker or LSX 440
Concerning the SD tune, that is the major reason why this MAF guy would go SD.
And 100mm MAF what good is a 100mm MAF when the leading end of the intake is maybe 90mm? Yea, where is the 100mm intake?
The benifit of a 100mm MAF is not having to run a smaller than 90mm MAF and restrict your 90mm TB & intake. SD tunes are good and accurate but when the weather changes so does your tune, with a MAF it can compensate for variancies in weather. I'm a nitrous guy and a MAF is good insurance for me, thats why I like running one. I have done a few SD tunes BTW, they take a lot of work to make them accurate and keep them accurate. VE tables are VERY touchy.
505whp with a stock L76 intake and 1 3/4 primary headers, but i will be going SD once i finish everthing else i want to do to the motor
JDP: Allen Park,,, 505 RWHp with a stock LS1 MAF is very impressive. I always want to ask in these cases is how much Hp do you think that you are giving up with the stock MAF VS 90mm MAF OR a SD tune?
Now all I have to do is tell the car what AFR I want and thats what it is, one of the things that made me give up my 383 carbed C3 Corvette, I love tuning and learning new things about EFI. My wife is now jealous of all the attention my WS6 gets, its a sickness!
We will be SD tuning the car next year to see what it will pick up, and adding a elec water pump and a set of 1 7/8 stepped to 2 inch headers at the same time, hoping to hit 500 rw thru the th400, which should put the car close to dipping into the 9's on motor, if the car works good enough/ weight is low enough (runs 10.54 to 10.57 consistantly now off the footbrake, at 3440 lbs)
