OK who has 6 bolt heads??
i need someone to poiint me in the right direction to find 6 bolt heads its for a hi boost application and will also be recieving a set of O rings i believe no more problems wanted with boost. anyways main concern is the heads please help.
I think the only companies at the moment are:
ETP
All Pro
World Products
The world products head will only fit their block so that leaves the first two if you are running an LSX block.
The All Pro's you have to use Jessel rockers and only come in LS7 style intake runners.
The ETP's you can use stock rocker with. The ETP's also come in cathedral port as well as LS7 port and a new L92 port soon.
Glenn
ETP
All Pro
World Products
Glenn
If your looking for a bad cylinder head setup, talk with Richard at west coast cylinder head (sponsor), We used them on a previous LSX boost motor and Richard's service was Top notch, we recived the cylinder heads in a fraction of the time of some of the other companys.
