Shakedown Passes w/ Kooks 1 7/8" to 2" - NA Hydraulic Roller - 9.94
Just wanted to say a huge thanks to Kooks!
Got the 417ci carb'd lsx to the track the other day in "The Kerminator". This was using a BG Race Demon 1000cfm carb, with the factory jetting and modest timing. Saw the MPH go from 132-136 at the track as the rings started to seal up and motor made some extra ponies. Looking to get her on the dyno by Weds. and see what this motor can produce.
Using Kooks 1 7/8" to 2" Stepped Longtube Headers we were able to power this untuned monster to a 9.94 @ 135.93 using a hydraulic roller camshaft. We are going back out this weekend to improve further on those times.
Their header quality is unmatched. When we step the motor up this winter we will be going with a set of 2" competing in the NOPI PRO Street Tire & NMCA Xtreme Street classes.
![](http://ttperformance.net/kerminator/DSCN1164.JPG)
9 Second Shakedown Pass
417ci L92 Block (4.068 Bore)
13:1 c/r
BG Race Demon 1000 CFM Carb
TTP Port/Polished AFR 225cc
TTP Port/Polished Victor JR
GRP STD 1200 C/Rods
Callies Dragonslayer 4.000"
Manley LW -4cc Flat-Top 4.068 pistons
th350 hughes transbrake
4200 Stall Vig (Not optimal)
GMPP Hi-Rev Lifters
Comp 26x/27x xe lobe cam .595 lift on 1.7 stock gm rockers
It's actually a pretty budget combination.
13:1 c/r
GRP STD 1200 C/Rods
GMPP Hi-Rev Lifters
