What's all needed to run carb on LS7
What is needed to run the carb?
LS7 carb intake
Do I use the MSD controller?
Thanks
D.J.
Is there any advantage running the 58x over the 24x other than if I wanted to put this engine in a c6 Zo6?
D.J.
I have the 6010 box, the wire harness is pretty nice that they give you. However, on my box the sensor ground was not grounded internally in the box and cost us over 7 hours of work, just to tap the other ground so the box would fire. But other than that bull, it works well. 9.94 on shakedown passes 417ci carb'd.
It's a very simple plotted chart for timing that you can connect via a laptop with a serial connection or serial-usb adapter.
If you don't want to mess with the timing they include some timing modules.
