Lifting L92 Heads
Old Jan 12, 2008 | 02:31 AM
spare tire's Avatar
Default Lifting L92 Heads
Like the title states, I wanna know if anyone has had a problem with lifting an L92 head? It doesnt matter which block you are running. I have been told that with boost over 12PSI that you will lift a head, I dont think the source is reliable but I just wanted to hear what everyone had to say. Because I want to do a 6.0L build with L92 heads.
Old Jan 12, 2008 | 02:52 AM
TurboGibbs's Avatar
Well, The new release of a cousin casting of the L92 is in the new LS9 (ZR1). GM states that they are using a stronger metal compound, less porous casting and a 4 layer (instead of traditional 3 layer) multi layer steel head gasket to help sealing with head movement. They are 10:1 comp and 10.5 lbs boost. If I was going FI i'd try to get my hands on some of those 4 layer gaskets.
This would explain why I lifted the heads on my turbo'd 6.0 with L92's on only 4psi. I had solid copper head gaskets and an o-ringed block. When I had 317's I saw evidence on my mls gaskets that they had been leaking by on 10psi boost. Both times it had ARP head studs.
Old Jan 12, 2008 | 08:52 PM
exploder's Avatar
boosting 15psi on mine and not lifted yet using mls gaskets.
Old Jan 17, 2008 | 12:01 AM
spare tire's Avatar
Thanks for the replys guys, I didnt even realize i put this in the wrong forum lol my bad
Old Jan 17, 2008 | 09:27 AM
camarols1's Avatar
Check out post #7 in this thread.
https://ls1tech.com/forums/forced-induction/759655-l92-heads-forced-induction.html
Many others have posted BIG power with L92's.
A good "safe" tune is obviously key to making good power with a production casting.
Speed Inc. recently did an awesome build with a 68 Camaro.
https://ls1tech.com/forums/forced-induction/826567-one-our-latest-projects-completed-921rwhp-18psi.html
The boys at Speed are well known for tuning safely to avoid problems.
Old Jan 17, 2008 | 11:43 AM
Shawn @ VA Speed's Avatar
https://ls1tech.com/forums/showthread.php?t=759655
https://ls1tech.com/forums/showthread.php?t=826567
not trying to hijack but i like your car,i have a soft spot for 79camaro's with twins
Old Jan 17, 2008 | 04:23 PM
camarols1's Avatar
Thanks for the compliment, now I gotta go change my underwear!
That is one BADASS ride for sure Shawn!!!
Hopepully I will have mine on the road in a month or so....
Old Jan 17, 2008 | 09:09 PM
Blindmelon's Avatar
SDPC has the new gaskets I thought I read 5 layer MLS gaskets. I will be using my set I just bought on my new L92 heads/cam change. I think SDPC said it will replace the old 3 layer on the L92 motors. The L92 heads got rid of the plug on the end of the heads used when casting. This change & better aluminum makes the L92/LS3 a more stable head with less movement & lifting issues.
