L76 on L92..need advice
Old Apr 14, 2008 | 03:05 PM
90pickup's Avatar
Default L76 on L92..need advice
Finally got my L76 intake on my crate L92. Now, I need injectors, because the truck ones can not be swaped over (different size). Should I go for LS2 injectors? Or aftermarket ones? And do the aftermarket LS2 fuelrails fit? thanks for advice m
Old Apr 22, 2008 | 06:39 PM
jtl12419's Avatar
Your injector choice will be affected by fuel rail choice-- for fitment issues.
First decide what type of rail you are using. The mounting brackets (height short or long) will determine what style injector you will go with. Then pick your injector.
Finally, you may or may not need electrical adaptors for the injector.
Do a search here
Old Apr 22, 2008 | 07:14 PM
3timeracin's Avatar
the injectors will work they require a larger o ring thats all. I have done this before they are available from some sponsors on here. That way you can use your rails and wiring still.
Old Apr 23, 2008 | 02:49 PM
90pickup's Avatar
Thanks a lot! Will get some billet fuelrails as well..thanks again.m
Old Apr 24, 2008 | 04:45 AM
subtlez28's Avatar
This is good news.
Can I get the specifics on the o-rings?
I assume the stock truck style rails will not be re-used.
Old Apr 24, 2008 | 05:46 AM
WKMCD's Avatar
Originally Posted by subtlez28
This is good news.
I got my o-rings fron Katech
Old Apr 24, 2008 | 12:41 PM
subtlez28's Avatar
Thanks!
Old Apr 28, 2008 | 01:27 PM
90pickup's Avatar
What I do not understand is that my L92 truck intake injectors are actually to big to fit into the L76 unit..?!? If I use O-rings they will not go far enough into the intake. Should I mod the inlet to made the injectors fit? thanks for advice.m
Old Apr 28, 2008 | 01:33 PM
garys 68's Avatar
I dont know if it's the same as the LS6, but check out this post on injectors:
http://www.performancetrucks.net/for...7&page=1&pp=10
Old Apr 28, 2008 | 02:46 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Is this true that truck injectors will not fit the L76 intake?
Old Apr 28, 2008 | 03:03 PM
90pickup's Avatar
Well this link gives my some hope! Thanks a lot, garys68! Will try to remove the plastic plug from the truck L92 injectors tomorrow. Billet fuelrails are on their way as well. Will post pic of the finished intake soon. Hopefully....!Thanks for all your help and inputs.m
Old Apr 28, 2008 | 08:30 PM
jtl12419's Avatar
Guy's, this is not a new topic. Do a search. Read post #2.
You do not want to mess around with injectors or O-rings that don't fit, with fuel at 65psi!!!!!!!!!!
Old May 2, 2008 | 01:29 PM
90pickup's Avatar
I know, it is not a brand new topic. But now I can say, that the L92 truck injectors can not be swapped into the L76 intake...And I still don`t know why. Anyway, new ones are on their way.
Old May 2, 2008 | 05:42 PM
garys 68's Avatar
I'm going to try an aftermarket fuel rail with my truck injectors. I'll let you know the results.
Old May 2, 2008 | 07:24 PM
the_merv's Avatar
I used LS2 Rails with LS2 #34 Injectors.. I had to shim the Rails up 1/2", haven't had any problem with leaks.
Old May 3, 2008 | 02:38 AM
90pickup's Avatar
I got Aeromotive LS2 fulerails as well and they seem to fit nicely. Just waiting for the injectors.
