Gmpp ????
Old Jul 3, 2008 | 12:32 PM
bada's Avatar
Default Gmpp ????
Does anyone know how to contact GM performance parts. I tried their web site. I need to get in touch with them to ask about a PCM
Old Jul 3, 2008 | 01:13 PM
IH8FORD's Avatar
Try SPDC2000.com They sell GM performance parts and will probally be able to help you with your question their # should be on the website.
Old Jul 3, 2008 | 04:19 PM
3fingas's Avatar
Or any chevr dealership
Old Jul 3, 2008 | 08:08 PM
bada's Avatar
Chevy dealer is no help. They looked at me like I was stupid, when I asked about the LS7 crate PCM.
Old Jul 3, 2008 | 08:17 PM
3fingas's Avatar
??? every gm (chevy,Pontiac) dealer ( in florida anyway) has access to gm performance parts. LS7 crate pcm? Are you talking about a LS7 pcm or Ls7 Crate motor? Not sure. When you order, you need the part number which can be found in their catalog.
Old Jul 3, 2008 | 08:38 PM
bada's Avatar
I understand that GM offers a PCM for their LS7 crate motors. I have a LS7 in my 32 ford, out of a wrecked ZO6. I am trying to get it to work now. But I am running a auto tranny, Plus I dont need all the vette junk. I heard Gm offered a PCM just for this type of application. But it is non-programable. I am also running the ZO6 cooling fan. So I need, that circuit in the PCM also. Just wanted to see if the PCM will do what I want. I have a part #. It is 19166567. So I need to talk to someone at GMPP that can help me out. I talked to Gene at GM parts house, but he gave me a different part #. Not sure he knew what I want eather.
Old Jul 3, 2008 | 10:03 PM
3fingas's Avatar
Gotcha. The stand alone ignition ecu is 19171130. But its meant for a carb. & 54 reluc whl & Coils. Sorry I didnt quite understand you at first. The ecu is not programable. I beleive some are swappin the ecu for a rebuild so you can write to it. Not sure if your just better off throwin in the pcm and programing out this **** you dont want. Dan @ Masport does it, He's a sponser here. Good Luck!
Old Jul 4, 2008 | 05:39 AM
Robin L's Avatar
LS1Tech Sponsor
So far from what I have seen you cannot re program the ECU in the stand alone kit. Now I have been told that guys are doing it. They had to burn a VIN into the ECU with a Tech II to get the software to accept the a VIN. The HP Tuners needs a VIN to lock into.
Since a ZO6 never came with an Automatic trans your not going t get that ECU to control te trans. You will have to get a stand alsone for the trans from someone like TCI.
Robin
Old Jul 4, 2008 | 10:09 AM
bada's Avatar
Thanks guys. I picked up a Camaro performers mag. And they used an LSX block with all LS7 internals, and the PCM they used was part #19166567. It made about 550 hp. Thats where I got the PCM # from. Anyone know about that PCM? they said it started right up and need no tuning.
