Need a LS3 MAP sensor part number
Old Jul 20, 2008 | 02:07 AM
rickou812's Avatar
Default Need a LS3 MAP sensor part number
I have a LS3 intake off a 2008 corvette. The map sensor has been moved to the front like the ls2's BUT it has a bigger hole and is bolted down. The map sensors for LS's will not fit, at least not with out creative modification. I have tried to search and find the part number for the new sensor but have had NO luck in finding it.
Any help is appreciated.
Rick
Old Jul 21, 2008 | 12:12 AM
rickou812's Avatar
Anyone???
Old Jul 21, 2008 | 07:18 AM
See5's Avatar
If you change sensors you will have electrical connector problems as the connectors are different. So:
You can make up a "Z" type clip to hold the old MAP sensor with fatter o-ring
or use the new sensor and solder up the connector pins inside the sensor plug. part #12591290
Old Jul 21, 2008 | 10:56 AM
rickou812's Avatar
Thanks for the info.
Can you explain what needs to be soldered, or was you just meaning to solder on a new plug that corresponds with the new Map sensor?
Old Jul 21, 2008 | 07:12 PM
See5's Avatar
I just make up a jumper by soldering to the pins inside the sensor connector then fill with silicone.
Old Jul 23, 2008 | 03:26 PM
TKO52's Avatar
call a gm dealer ship i dont have the part number near me but they do have them i belive it was around 80 dollars for supplier price
Old Jul 31, 2008 | 02:32 PM
camarols1's Avatar
The GM part number for the LS3 MAP sensor connector is 88988583
A builder of mine ran into the same situation and just wired in
the LS3 style wire connector from GM.
Old Aug 1, 2008 | 04:58 AM
drain89's Avatar
ouch what a PITA
Old Feb 18, 2009 | 07:49 PM
79TransAmLS2402's Avatar
Hey guys, I'm doing a swap myself and I got a engine harness that was all chopped up from the junkyard and I use EFI Connection to get all my pigtails. They are way cheaper then GM and still have GM quality. A LS3 MAP sensor pigtail is 15.00 from this place.
Old Feb 18, 2009 | 09:14 PM
405HP_Z06's Avatar
Katech offers a conversion harness, a little pricey but no cutting or soldering. Plug and go.
http://store.katechengines.com/share...unt2=943824410
Old Feb 19, 2009 | 09:45 AM
See5's Avatar
I have a bunch of plugs and pigtail harnesses if anyone needs them.
Old Sep 14, 2011 | 08:37 PM
samckitt's Avatar
Anyone have a place to get them? I have seen a few places online, Pace, GMPartsdirect.com, etc & average seems to be around $30 for a little connector. That is nuts.
Old Sep 16, 2011 | 01:22 PM
KENS80V's Avatar
see post #9. I get all my harness parts from them too.
Old Sep 16, 2011 | 02:48 PM
Mike454SS's Avatar
Please also be aware that the LS3 MAP sensor is NOT a 1 bar sensor. In order to run it in an LS1 car, you will need an enhanced OS where you can adjust the MAP Linear to 128.13 and Offset to -0.31, which are numbers taken directly from a stock LS3 Camaro tune.
That said...when I set the offset to -0.31, the file wound up writing it to a 0 anyways as apparently the 2 bar OS from HPTuners can't accept a negative value there...but in my friends car running an LS3 MAP sensor, setting that to 0 with the correct linear, has resulted in acceptable MAP readings.
