Bolt ons to get the most power out of LS2s
I was wondering what the best heads are and i am planning on a custom cam and a good tune after that. Wouldn't mind making a really good top end to get some lift of the valves. I'd like to see 400+ rwhp out of it. I am looking for good reliability and to keep it drivable. I have headers for it as well. It's my first 'not stock' build so i need so help in the right direction.
A custom cam is definitely not a bad idea. Contact Ed Curtis from Flowtech and he can take care of you on an awesome custom cam that will have great street manners, as well as set you up with cylinder heads.
With just a cam alone you'll easily get 400+ rwhp. These LS2's put down around 340 hp at the wheels in the M6 GTO's. Add a cam, headers, and a high flow intake and a 6-speed GTO will see 415-435 at the wheels. That could be nearly 450 rwhp in your F-body. Add a set of heads and you've just blown that 400+ goal away and you'll be approaching 500 rwhp I'm sure. So it won't take much!
Is that with just the cam, headers, ported fast?? No other little goodies to get to the 440rwhp?? THAT IS NASTY!!!
Cole
LSx Mongoose Aluminum Cylinder Heads 205cc Intake Ports, 66cc #033-1510
LS1 Hydraulic Roller Cam, Comp Cams, AFR Custom Grind #6019
.580x.590, 114 degree
(@.050in)…230 deg in/232 deg exh
LSx Cometic Head Gasket, 4.160" X 0.040", LS2 6.0L #COMC5318-040
for 11:1 compression
FAST intake
42 lbs injectors
Ported stock 90 mm TB
E3 plugs
