Who has best deal on L92 heads?
"One more enthusiast who knows that L92 is not necessarily the BEST head available."
Who's saying they are the BEST moron? They are a great flowing factory head that is CHEAP. Very much cheaper then the AFR's, sure the afr's are a better head all around, but they cost over twice as much. Most people are trying to go as fast as they can for as cheap as they can, thats what hot rodding is all about. Get a clue KID.
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
Texas Speed has the cheapest deal on L92 heads. Also if you can afford it you should have Patrick G set them up and custom grind you a cam to match it you won't dissapointed
foreal if you wana get nasty and you want serious power get the trickflow 235's you'll spend more but you get what you pay for i'm still stock cube till next year but i'll hit up a pair of 215's with a 92/92 then the 235's when i build the 427. . . . www.totalengineairflow.com call them on heads and Pat G for a cam
Moderator
Personally I have bought many parts from TSP and never had a problem. I wouldnt hesitate to grab thier cnc'd L92's. Im just waiting to see what Vengeance puts out (pwr/$$) with thier heads since I have thier LS3 cam. Who has had a problem with TSP L92's? Anyone? Doubt it. ![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
This is how a bad reputation gets started on the internet. If Vengeance heads are $$, I will have TSP heads myself.
You get what you pay for.
Moderator
I figured it would be a general cliche. Let me guess, Patriot L92's (soon to be released) will be poor performers too since they will be affordable. What you are saying is if someone spends an etra $500-1000, they are going to have more power, 100% of the time. Not so true these days. Who in thier right mind isnt concerned with performance per dollar.
Moderator
Lets try it AGAIN.
Me, I have had great success with TSP in the past. Their L92 have also shown hp gain when they tested them and atleast 1 other member I know of on here had positive tested results.
https://ls1tech.com/forums/showthrea...ht=6.0+233/239
Im sure 6 pages of proof will outweigh your stupid azz BS.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Now what specfic problems did YOU have with TSP products?
#32
My concern as a Mod here is that you are dragging TSP's (a sponsor here) name through the mud and I asked what your gripe was and all you said was " you get what you pay for " with no detail outlining your bad TSP expericnce and then you attempt to insult me like a child. The exact aittitude that offers nothing to LS1tech when someone is making a decision to buy something from the vendors. Good job, I will be sure to get your advice since it is so detailed on the pros and cons of TSP's products.
Lets try it AGAIN.
Im sure 6 pages of proof will outweigh your stupid azz BS.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Lets try it AGAIN.
![Ridin' the sack](https://ls1tech.com/forums/images/smilies/sackrider.gif)
As a mod, calling my comment's stupid azz is a great reflection on who the azz is.
![Leghump](https://ls1tech.com/forums/images/smilies/LS1Tech/leghump.gif)
I've owned plenty of TSP product along with numerous friends. Two shortblocks and two set's of cylinder heads personaly. Garbage porting, garbage valve job, gigantic port size and flow numbers a BIT shy of advertised. Crap crank machining, crap tolerance on rings and bearings, crap block clearancing causing one shortblock to self destruct. It's cheap for a reason and you get what you pay for. I could care less about 6 pages of TSP cheerleading. There is plenty of post's to support my claims, unless they have been removed.
Let's hear about all the TSP product you have owned........
#33
Moderator
You asked what my gripe was??? Hmmm, I must have missed that. As far as dragging their name through the mud, commenting that they are cheap is mud slinging? ![Ridin' the sack](https://ls1tech.com/forums/images/smilies/sackrider.gif)
As a mod, calling my comment's stupid azz is a great reflection on who the azz is.![Leghump](https://ls1tech.com/forums/images/smilies/LS1Tech/leghump.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Just curious, who installed these terrible parts? No operator error at all eh?
#36
I just noticed your feeble attempt to discredit my comments. I installed my parts, my friends installed thier own. My mechanical ability is not the question.
TSP's ability to provide a competant product is. If you would like to discuss how my installation of TSP product caused "Garbage porting, garbage valve job, gigantic port size and flow numbers a BIT shy of advertised. Crap crank machining, crap tolerance on rings and bearings, crap block clearancing causing one shortblock to self destruct." these lapses of quality, fire away.
Either you can't read or you have zero mechanical ability/knowledge to suggest an install could cause these problems. Thanks for playing, you did'em proud!!
