lifter solid
Old Nov 12, 2008 | 02:34 AM
DASHTI's Avatar
Default lifter solid
i want lifter solid roller link bar dim. up 890 where can i find it
Old Nov 12, 2008 | 09:33 AM
njc.corp's Avatar
Cool
hmm-look up jesel,lsm,morel,crower,comp,crane
Old Nov 12, 2008 | 09:42 AM
bayer-z28's Avatar
Morel and Lunati lifers are identical pieces, FWIW...
Old Nov 12, 2008 | 02:29 PM
Brent@LPE's Avatar
We are having problems with morel solid lifters in a warhawk block at the moment. We are having them fixed right know.
I have some jessel stuff in stock
Call the shop if you need some help
260-244-4808
Brent
Old Nov 12, 2008 | 04:21 PM
njc.corp's Avatar
Smile
crane too? thats what i have been told lately-
Old Nov 12, 2008 | 04:22 PM
njc.corp's Avatar
Question
260-244-4808
Brent
i saw that bob mention something in a other post-
u having problems with morel with just the warhawk block or just in general?
Old Nov 14, 2008 | 11:19 AM
Brent@LPE's Avatar
hey Nick,
It looks like with just the warhawk. It has to do with the edge orfice that sends oil up the pushrod. It is croos drilled and "falls'' into the oil galley allowing all the oil to flow up the pushrod. We sent them back to morel to have one side plugged.
When they get back I will make a post about it with pics.
FWIW the jesel is already plugged.
Brent
Old Nov 21, 2008 | 01:20 AM
racer7088's Avatar
Arrow
Most Solid Roller lifters do not work with the LS1 at all including many that even say they do. You also have to know what you are really doing with the engine to pick which lifter to use as in lobe lift and spring pressure etc. Some Morels work and some do not. It all depends.
Old Dec 4, 2008 | 11:01 PM
njc.corp's Avatar
Smile
erik-interesting-for someone who has no engine building skills or a little-
what do you do?
which one do you get?
do u get the cam and all the spec's first and ring the lifter mob of your choice
Thanks
Nick--
Old Dec 4, 2008 | 11:12 PM
racer7088's Avatar
Arrow
what do you do?
which one to you get?
Thanks
Nick--
Too much to get into for an internet thread basically. There's a lot to go wrong and you just have to know how it all works. I have had to return most "LS1" solid roller lifters that people have supplied me with and use what I know works with that lobe lift and design etc. Several of the solid rollers will lose nearly all your oil pressure and some cannot mechanically accomodate that much lift and some require extensive block modifications to not bind up. When you get into the really bigger lobe lift stuff it just gets even worse.
Old Dec 7, 2008 | 09:08 AM
Gen414's Avatar
what do you do?
Thanks
Nick--
Nick, PM coming, and you can take Erik's word for it, he knows his s***
Old Dec 7, 2008 | 10:54 AM
Daryn's Avatar
Formerly darynC-10/23/10
for my solid build i am going to be goin with a bullet solid cam and bullet solid lifters.
bullet and lunati are also 2 of the same company
