opinions for 402 head choice
car will be a 100% street car with maybe 1-3 track passes a year, im hopeing to make around 525whp
im down to decideing on my pistons cam and heads
i'd like to run a ported fast 92 on it, best place to get a ported one at?
heads i was looking into a set of afr's ive seen the 205's are pretty good on 402's would the 225's be better tho? what non super expensive rocker arms would you recommend
compression ratio? i was thinking 11.5:1 would be 93 pump safe?
now what kind of pistons would you recommend flat tops with valve reliefs ect?
i was also thinking of running a u/d pulley
thanks in advance
Contact Tony Mamo at AFR.
The 205's have put out great results on 402 motors. I run 225's with additional work by Tony. Whatever brand you go with; don't skimp on cylinder heads. They are the key to making big power on n/a cars.
I run 11.8 on pump gas without a problem.
now what kind of pistons would you recommend flat tops with valve reliefs ect? I've used both Wiseco and Diamond pistons (2 cc valve reliefs) with good results. In my case the Wiseco pistons are slightly lighter.
I run an ASP pulley with no problems.
I also have AFR's on sale and can come up with a package deal for you for cam heads and intake.
You dont need after market rockers with AFR's, I would just have your stockers rebuilt by Harlan Sharp. The HS mod fixes the only issue with them. I'd go with the 225's over the 205's, the price is close enough anyway and Like I said I have them on sale
now, if i hadnt bought the ported 205s before, i either would have gotten the 225 AFRs or maybe a set of worked over L92s
Fully race prepped New titanium intake valves and slightly used inconel exhaust valves. For 2650 delivered
ready to ship should be easily over 500whp with a ported fast intake
Yes to the intake Jesel's on the rocker. Big rpms requires a stable rocker system. The offset pattern provides just that.
I carry Richards heads
, as well as run them on my personal cars
Richards is great guy to talk to and very helpful as well give him a call. if the dollar was at least 1 bit decent i would talk but no good-
thanks for the offer
Thanks
Nick--
Several more threads with other head result in the dyno section.
Good luck with your build!
but as always u must check the measurements-
my one got the cut out for the ls1 rocker stands-
we are talking about the allpro head yea?
Thanks
Nick--
