Best main bearing option for a crank cut .020
Restricted User
Well I had my Lunati 4" crank magnafluxed and had spider cracks as well as some grooving. It was already cut .010 .010 and now needs cut again to .020 .020. I found the rod bearings I wanted with no issue... But cannot find a good high end .020 oversize main bearing. The FM 152m bearings only come .10 over size and the same with the Clevite 2199H series. So what are my options here??? The best I could find was a Clevite MS2199P20. Will this suffice??? Or is their something better?
Thanks
Mark
Thanks
Mark
