LX CNC LS7 style manifold by Performance Induction
Attachment 215157
Attachment 215158
I take it that you have the CNC version with the 4500 flange?
Is that the L92 version?
Hmmm...
We also had to increase the timing from 34 to 38 degrees.This intake with LS7 heads acts like a Big Block.
Ray T
Above is a Carey Manifold & Edelbrock TB on a car with Higgins Race Development LS7 heads, 445ci LS7, 13:1 263/271/111 cam.
The car is a Holden Torana LJ and will weigh 2600-2800lb with driver. Its running a Craigs Automatics built 4L65e , CircleD 5000 converter and a 3.5 ratio 9" diff.
The engine hasnt been started yet. Its a work in progress.
Attachment 215157
Attachment 215158
But like Cary said I had the C5R intake and it is a little taller than the others.
Should still give you a rough idea of how much clearence you need.
