PRC 237cc Specs / Flow / Pics INSIDE!!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
This is what I was told about my heads from them, a few yrs ago. They are the 2.5(R) LS6 heads they had a while back. Around 2006.
correct..they didnt release these as a "budget" or "lower quality" casting than a AFR or TFS. They are direct competitors that should make comparable (or hopefully better!) numbers and results for a comparable price.
We have some on order and cant wait to use them.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Compare these heads to the TFS 235cc heads on a 4.030" bore fixture (the exhaust #'s are not compareable as the TFS heads are with a 1 7/8" pipe vs no pipe for TSP)
Is this True about the TFS head not flowing more cause of them being flowed with a 1 7/8 pipe ?
A pipe on the exhaust will increase the numbers.
