PRC 237cc Specs / Flow / Pics INSIDE!!
The 237cc port is a supersized version of the 215cc cylinder head that recently claimed the quickest heads cam record!! The 237cc port is designed for customers with 4"+ bore applications looking for a max effort cathedral port cylinder head!
The 237cc cylinder head ships with the following:
- 2.100" Stainless Intake Valves
- 1.600" Stainless Exhaust Valves
- PRC Double Spring Kit (.650" Lift)
- 68cc CNC Machined Chambers
- Provisions for Stock Rocker Arms or Aftermarket Rockers
- Increased valve cover clearance for aftermarket rocker systems
- Thick Deck for better sealing in power adder applications
- 6 bolt option standard for LSx blocks!
- .700" Valve Spring Upgrade Available!!
Flow Data:
Lift Intake Exhaust
.100" 66 cfm 57 cfm
.200" 147 cfm 117 cfm
.300" 225 cfm 170 cfm
.400" 284 cfm 206 cfm
.500" 325 cfm 227 cfm
.600" 334 cfm 235 cfm
.650" 339 cfm 241 cfm
More info available at:
http://www.texas-speed.com/shop/item...d=992&catid=20
Preordering for 215, 227 & 237cc versions available with estimated ship time of mid Jan.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Zach
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Compare these heads to the TFS 235cc heads on a 4.030" bore fixture (the exhaust #'s are not compareable as the TFS heads are with a 1 7/8" pipe vs no pipe for TSP)
How are they vs the 6bolt trickflow 235 heads?
Is there any way to get the warhawk bolt pattern on this?
Is there any room for hand porting?
