which lifters?
Old Dec 26, 2008 | 04:24 PM
CUR 4 VNM's Avatar
Default which lifters?
i need some hydraulic roller lifters. i dont know which ones to go with and its for a 408 with tfs 235's? morels, ls7, etc...?
Old Dec 26, 2008 | 05:20 PM
Shawn @ VA Speed's Avatar
I've had extremely good luck with the ls7's up to .620 lift,after that i usually run the Morel's
Old Dec 26, 2008 | 06:11 PM
JPH's Avatar
JPH
How big is the cam and what year block are you using?
Old Dec 26, 2008 | 10:43 PM
CUR 4 VNM's Avatar
my cam is a 247/255 624/624 lift 112 lsa. my block is a hke iron 408.
Old Dec 28, 2008 | 01:49 PM
CUR 4 VNM's Avatar
bump....
Old Dec 28, 2008 | 08:49 PM
1cdub's Avatar
what makes them good to only .620 lift? what varies specifically between the LS7's and the Morels?
Old Dec 28, 2008 | 10:26 PM
Daryn's Avatar
Formerly darynC-10/23/10
spring pressure is a factor too.. just get some morels.. you have spent the $$ on the rest of the motor why skimp on the lifters?
Old Dec 28, 2008 | 10:37 PM
firefighting1101's Avatar
i went with morel link bar lifters on my 408
Old Dec 28, 2008 | 10:43 PM
njc.corp's Avatar
Question
u got a cost $$$ idea on the link bar morel's?
Old Dec 28, 2008 | 11:19 PM
Daryn's Avatar
when they were fresh on the market i got a quote somewhere around 500ish
Old Dec 29, 2008 | 07:19 AM
CUR 4 VNM's Avatar
i found them for $495
Old Dec 29, 2008 | 06:32 PM
remember though the lifters take all the abuse from every rpm the motor goes through. its not a part to skimp out on. ans with as many ls7 and caddy lifter failures as ive seen i certainly would not waste my money or risk my motor on those. i beleive the lunati's are built by morel aswell.
Old Dec 29, 2008 | 08:10 PM
jobe_ls1's Avatar
I just bought the CTS-V lifters as I thought these were a good upgrade. What kind of failures have you seen and what has caused them I am now hesitant to use these lifters.
Old Dec 30, 2008 | 06:24 AM
Mazzenger's Avatar
I would personally not install the CTS-V Caddy Lifters. I had one fail after 2500 miles.
Old Dec 30, 2008 | 06:49 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
go with morels ,and call it a day.
Old Dec 30, 2008 | 07:03 AM
speeddemongto's Avatar
damn morels are not cheap
Old Dec 30, 2008 | 01:07 PM
jason99frc's Avatar
Check out the new Comp units. Im currently waiting on a release date and exact $. They are in the new brochure (short travel precision blah blah)
Old Dec 30, 2008 | 06:05 PM
CUR 4 VNM's Avatar
morels are ordered thanks guys!
Old Dec 31, 2008 | 12:45 AM
racer7088's Avatar
They are available and are the same price range as Morel at around 500ish or so.
Old Dec 31, 2008 | 09:25 AM
jason99frc's Avatar
Yeah Tim from comp told me @ PRI they were available, unfortunately a call into comp yesterday showed no availability at this time and no release date in their cpu system. I will contact Tim when he returns from vacation next week.
