Cam Lobe Specifications Compilation
Old Dec 29, 2008 | 12:57 AM
405HP_Z06's Avatar
Default Cam Lobe Specifications Compilation
Cross posted from the Gen III internal engine section:
I've gathered all of the cam lobe data I can find for the LSx engine platform into a single document. Currently, these only include lobes from Comp Cams, Crane Cams, Lunati Cams, Cam Motion and Isky Racing Cams. I figured someone else could use the data so here it is.
Lobes included in the attached document:
Lunati Cams
  1. Baseline Series
  2. Baseline Lobe Family
  3. CNC Low Lift Series
  4. CNC High Lift Series
  5. .328 and .353 Lift Series
  6. LS Voodoo Series
Comp Cams
  1. Xtreme RPM Low Lift
  2. Xtreme RPM High Lift
  3. Xtreme Energy XE-R
  4. XFI Intake
  5. XFI Exhaust
  6. Thumpr Intake
  7. Thumpr Exhaust
  8. Xtreme Energy LSL
  9. Xtreme Energy LSK
  10. Xtreme Marine
  11. Xtreme Marine High Lift
  12. Cheater HR
  13. RP
  14. SP
  15. Xtreme Tri-Power
  16. Unknown category
Crane Cams
  1. HR1
  2. HR2
  3. HR3
  4. HR4
  5. HR5
  6. LSHS
  7. HIR
  8. HR400
Isky Racing Cams
  1. HRX Series
  2. High Performance Series
Cam Motion
  1. Hydraulic Roller Lobes
Any and all feedback welcome. If anyone has Crower lobe data I would appreciate it.
File Type: zip
Old Dec 29, 2008 | 09:54 AM
Patrick G's Avatar
LS1 Tech Administrator
Nice work. Lots of lobes in there. There are a good number of Comp lobes that work well with the LSX platform that have been left off (like the Xtreme Marine High Lift Lobes, some of the Cheater HR lobes, the XE High Lift lobes between 256-270 at .050", and the hydraulic-compatible solid roller lobes). I'm sure you will have lots of updates from shops too.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 29, 2008 | 11:52 AM
405HP_Z06's Avatar
Thanks Patrick, I sent you a PM. I hope this helps someone else.
Old Dec 31, 2008 | 02:57 AM
405HP_Z06's Avatar
Updated document with input from Patrick G , JPH , and Matt @ TSP . Thanks for the valuable input.
See first post, document is now attached instead of the external download link.
Old Jan 2, 2009 | 03:52 AM
405HP_Z06's Avatar
Updated to version 1.2 to include the Lunati Cams LS Voodoo Series hydraulic roller lobes.
Old Jan 3, 2009 | 04:49 PM
382ssz28's Avatar
Don't forget the new Comp LSR! Great Job!
Old Jan 3, 2009 | 07:21 PM
405HP_Z06's Avatar
The new Comp Cams LSR cams use LSL lobes. AFAIK, Comp Cams doesn't have a set of hydraulic roller lobe masters called LSR.
Old Jan 5, 2009 | 09:00 AM
382ssz28's Avatar
Gotcha!
Old Jan 6, 2009 | 07:54 PM
405HP_Z06's Avatar
TTT, version 1.3 posted. Added additional LSK lobe specs and Comp Cams solid roller lobes.
Old Jan 6, 2009 | 10:36 PM
DrkPhx's Avatar
Very nice job. I know some cam manufacturers have lobes they don't publish. It sure would be nice to see those specs.
Old Jan 10, 2009 | 06:19 PM
405HP_Z06's Avatar
TTT, updated to v1.35. This version includes some additional Comp Cams Xtreme RPM High Lift lobes.
Old Feb 6, 2009 | 12:19 PM
405HP_Z06's Avatar
TTT, updated to v1.40. Includes Cam Motion hydraulic roller lobes, Crane HR400 lobes, and some missing Crane lobe data. Thanks to JPH.
Old Mar 14, 2009 | 12:04 AM
405HP_Z06's Avatar
Updated lobe list posted. I added various lobes in many Comp Cams families plus
  • Thumpr Intake
  • Thumpr Exhaust
  • Xtreme Marine
and added specs on existing lobes that was previously missing.
Enjoy.
Old Mar 14, 2009 | 08:30 AM
ringram's Avatar
Sticky candidate surely!
Old Mar 14, 2009 | 08:44 AM
69LT1Bird's Avatar
I can't get your new file to work, does anyone else have the same problem?
Old Mar 14, 2009 | 09:29 AM
405HP_Z06's Avatar
I switched to the new version of WinZip and had similar problems recently. I changed the compression method and reposted.
Old Mar 14, 2009 | 01:46 PM
69LT1Bird's Avatar
Thanks, this is a great list.
Old Apr 12, 2009 | 10:43 PM
405HP_Z06's Avatar
Updated cam list.
Old May 29, 2009 | 11:44 PM
405HP_Z06's Avatar
TTT
Old May 30, 2009 | 10:08 AM
94 guy's Avatar
i can't open it?
