LS2 new build, no oil pressure ?
Old 12-31-2008, 05:53 AM
  #41
stevieturbo's Avatar
Originally Posted by edcmat-l1
That's a good question. I believe the factory cover has o-rings in the cover that aren't part of the gasket. IIRC
I'll look at one when I get to the shop. Sounds like the cover design needs to be refined.
Cover is simply a flat piece of Aluminiuim, with the engraving, and recesses machined for the bolt heads.
Underside is totally flat.
I'd assume this isnt the first one that's been sold.
Old 12-31-2008, 05:54 AM
  #42
edcmat-l1's Avatar
LS1 gasket is a different shape though, as the top of the velley is a different shape. So that isnt a possibility ???
I had been using an LS6 block previous...so I knew it was the wrong shape and needed to source a new one
Yeah, thought about it for a few and changed my post. It's an LS2 gasket, but the cover didn't have the o-rings in it like the factory cover.
Old 12-31-2008, 06:04 AM
  #43
Almost makes ya wonder why some people bother making these aftermarket parts.....when they arent doing the job they are supposed to.
At least if I had been informed before hand, it could have saved me a LOT of hassle.
Old 12-31-2008, 06:33 AM
  #44
edcmat-l1's Avatar
yep.......
Old 12-31-2008, 06:54 AM
  #45
jay_lt4's Avatar
you are correct, the factory cover has groove's cut in it for o-rings that go over the dod holes and seal them
Old 12-31-2008, 10:29 AM
  #46
racer7088's Avatar
Yea they should have told you that you would have to block those holes!
Old 12-31-2008, 10:53 AM
  #47
It's in and seems to be running fine anyway :-)
Old 12-31-2008, 07:41 PM
  #48
Shawn @ VA Speed's Avatar
glad you got it figured out
Old 01-02-2009, 04:03 PM
  #49
JFM-jr's Avatar
I wonder why the DOD towers are even cast into the LS2 block what vehicles employ DOD with the LS2 block? FWIW yes the factory LS2 cover does indeed have O-Rings in the bottom of the cover.
Old 01-05-2009, 05:09 AM
  #50
LS1MCSS's Avatar
I am glad I found this post. I am putting together a TSP 418 and was wondering if I would need to plug the DOD Towers. Now I know for sure that I will.
Old 01-05-2009, 06:45 AM
  #51
jay_lt4's Avatar
if you use the ls3 style cover you dont need to plug the holes
Old 01-05-2009, 11:50 AM
  #52
If you buy a billet aftermarket cover from a sponsor like I did......you will need to ensure the holes are sealed up....
Wish they had told me that whan I bought it.
Old 01-05-2009, 01:29 PM
  #53
XtraCajunSS's Avatar
I wish I would have seen this thread earlier. I could have solved the problem for you right then. I build an LS2 402 for a Magnacharged car probably about 3 years ago. We got one of the prototype Magna valley covers...
yep, you guessed it, only about 10psi oil pressure at idle and max of 40. There were no o-rings included with the cover...
Needless to say, its never happened again.
Shane
Old 01-05-2009, 11:25 PM
  #54
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I get about a call every few months where the lack of these o-rings caused lower oil pressure. The only Gen IV blocks that do not require plugging or o-ring seals are the LS7 and LSX, those two don't need the o-rings and maybe the LS9.
Quick Reply: LS2 new build, no oil pressure ?
