L92 cam recomendation
This is in a 2900lb Mustang,N/A Carb setup.
I am sure Mikey at Rapid could design one for your combo.....
He hit mine dead on!
10.19@136.22 with a soft 1.55 60'
We haven't done any 6.0's but our 427's get a 228/236 Cam and make 525-555 rwhp 490-520tq depending on bolt-ons.
A mail order tune probably isn't going to cut it on a build like yours. It may be close, but you may have quite a bit on the table.
What is your exhaust setup? Headers?
At that point it may be worth swapping the intake for something that is proven. (L76), your intake is a variable. I recall your thread when you built it, and it was nice work, but without playing on an engine dyno to optimize plenum size and runner length and a host of other variables, you are just guessing.
I'm going to get one of the tuner packages this spring but I can't see 100 hp in the tune.
I wonder if stock L92s will like the same????
Changed to a Comp custom grind that speced out at 228/236, .619/.610, 114LSA +2. Also changed to an under drive pulley during the cam swap. New cam with UD pulley made 465/412. Torque peaked at 4700rpm and HP at 6400. Idle not quite as mean and little or no cam surge with a little better MPG thrown in. Not near the torque of the other cam. Pulls hard a little longer though.
