L92 cam recomendation
Old Jan 15, 2009 | 06:57 AM
  #61
the_merv's Avatar
Veteran: Air Force
Originally Posted by HPfreak820
I spoke with Mike from Vengeance Racing and he told me these heads like big split on the duration and a bit more lift with a wider LSA. Does anybody want to chime in wether they have a different bumpstick where it has a small split in duration and narrower LSA's and how well they've worked for you.
Mine is one of the earlier spec'd Cams for L92 Heads.. 243/247, .621/.612, 114+3 LSA. I don't have any numbers on it, I still have some small issues to work out with the car (needs new O2's), but once I finish my T56 Swap, I want to Dyno it and see what it's got. It pulls hard through the RPM's.
Old Jan 15, 2009 | 08:53 AM
  #62
8ByGoat's Avatar
Originally Posted by gnfan
Listen to 8ByGoat, and look how fast is car is. Looks like he has a good combo.
Thanks....
Old Jan 15, 2009 | 01:56 PM
  #63
mike c.'s Avatar
The LG Motorsports G6X3 designed for the l92 heads. I have a ported set of 92's stock l76 and made 517hp 468tq. It was an custom 248/254 112 cam. then I switched to the LG g6x3 smaller cam and gained big. I have not dynoed yet,but I pull my buds camaro by more then a full car from a 60 to 120mph roll. Before I could only get him by 1/2 car. Dyno will happen in spring. the cam drives great around town and sounds like a muscle car.
Old Feb 1, 2009 | 11:46 PM
  #64
dkbykesdk's Avatar
just ordered mine cant wait till my car is done
Old Feb 2, 2009 | 12:16 AM
  #65
CamaroRick's Avatar
I run an off the shelf cam for the LS1 heads in my l92 setup, similar specs as yours 248*/254* .612"/.624" it made 503rwhp on a mustang dyno on a 6 speed midrange is on the weak side, low end it a little rough. I am going to swap a new cam in when i get some solid proof on what works. I want to know what kind of power gains you get out of the g6x3 cam
Old Feb 2, 2009 | 05:06 PM
  #66
steve40's Avatar
any idea on what the specs are off the g6x3? working on a 6.0 with l92 heads right now....still deciding on the intake and cam to use.
Old Feb 2, 2009 | 05:21 PM
  #67
l92's Avatar
l92
hey man check out this article ls2 with l92 heads with livernois cam with dyno results http://www.gmhightechperformance.com...ads/index.html
Old Feb 2, 2009 | 08:44 PM
  #68
91Z28's Avatar
Ok, it seems to me that a lot of people are recommending bigger I/E duration splits for the NA L92/LS3 head combos. Is this to "crutch" the weak (relative to intake flow) exhaust port? Because if so if you have PORTED L92/LS3 heads then I'm sure you don't need the larger split because looking at the flow numbers out there it seems ported L92s are heavily improved on the exhaust side and only slightly improved on the intake side. If you have ported L92/lS3 heads then picking up one of those "large split" cams wouldn't be the best idea.
Old Feb 3, 2009 | 08:55 AM
  #69
WKMCD's Avatar
Lot's of good information here.
https://ls1tech.com/forums/generatio...us-plan-b.html
Old Feb 26, 2009 | 03:11 AM
  #70
hymey's Avatar
I like the idea of the 112+0 230-236 cam that Kevin recommends. I have tried only a couple of cams both 6 degree splits. I have tried wide lsa and closer lsa. I like the tighter lsa cam, ie 112. It really makes the mid punchy, as seen in this thread a guy went from a 232 234 112 to a 228 236 114, gained less then 10hp and lost 30 foot pound of torque. I would have liked to see a 230-236 or 230-238-112 112+0 run in his combo. Would have gained up top and made a little more torque. You can get the surging out with a good sd tune.
If you are running a 112+0 cam(the L92s dont mind later ICL helps port velocity at low rpms) then the exhaust centreline is 112 BTDC. So with a 236 cam we would have a EVO at 50 deg BBDC@0.050". That is plenty early enough. The same cam on a 114 LSA+2 has a 116 ECL. That will open ex at 54deg BBDC@0.050" lift. Only 4 deg less but I would only do so if I was adding NOS or blown engine to scavenge the cylinder faster.On a NA combo it has the potential to lose cylinder pressure at low to mid rpms. There are a lot of fast L92 headed cars running tight splits in the range of 111-113 installed straight up combined with traditional splits, eg. low 230s intake duration, late 230s zorst duration, with around 3btdc IVO 47 abdc IVC and as previously mentioned an early enough 50bbdc EVO and 6 atdc EVC. I look at the valve events as much as LSA etc, as it all comes down to valve events. Those specs would give plenty of mid range hit. I would use them in a stroker with a 234 240 or 236 242 112 like kevin has tried and a little less duration on a 6L.
Old Feb 27, 2009 | 10:46 AM
  #71
8ByGoat's Avatar
Like mine........
