better head?
Old Jan 13, 2009 | 03:06 PM
redhotev1's Avatar
Default better head?
For street which head would be better L92 are Ls6 & runner size for stock L92. Looking to put in F body.
Old Jan 13, 2009 | 03:32 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
What short-block are you running?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 13, 2009 | 05:38 PM
Fifedogg's Avatar
I've had some good luck with my ported LS6's. They work great for my setup.
Old Jan 15, 2009 | 05:50 AM
redhotev1's Avatar
L92 shortblock arp rod bolts looking at ms3 for cam.
Old Jan 15, 2009 | 06:32 AM
the_merv's Avatar
The L92 Heads probably won't like that MS3, go with some ported LS6's and a LS6 Intake if you go with the MS3.
These L92 Heads are really bitchy when it comes to Cams.
Old Jan 15, 2009 | 09:03 AM
You'd have to flycut reliefs into your pistons for clearance with that camshaft and L92 heads. Like mentioned, it's also not my first choice for an L92 headed car. If you're set on the Magic Stick, I'd definitely consider LS6 heads!
__________________
Old Jan 15, 2009 | 09:17 AM
ss.slp.ls1's Avatar
Ported 243's. You need to do some research to put together a nice cammed L92/L76 set up. There is much debate on what "works" with those heads, I would strongly suggest you look into it before you go that route.
Old Jan 15, 2009 | 09:26 AM
KroMiniX's Avatar
Asians by far
Old Jan 15, 2009 | 09:34 AM
ss.slp.ls1's Avatar
Originally Posted by KroMiniX
Asians by far
They are tighter too!
Old Jan 15, 2009 | 03:06 PM
redhotev1's Avatar
Not set on Ms3 still looking and planing.
Old Jan 15, 2009 | 03:09 PM
redhotev1's Avatar
Looking at intake also
