Moving Knock sensors on a LS2 block
Old Jan 20, 2009 | 08:52 PM
DBRODS's Avatar
Default Moving Knock sensors on a LS2 block
Hey guys need a little help here. Im currently doing a LS2 swap in a 1995 Chevy truck and ran into a knock sensor problem on the drivers side. I relocated the 02 valley knock sensors to the sides of the block where the stock LS2 ones are. The problem is the driver side sensor is about an inch from the header. Is it ok to move the sensors to one of the rear motor mount holes on the block. I didn't know if it would affect anything, and I would move both sides accordingly. Thanks again Jon
Old Jan 21, 2009 | 06:07 AM
JFM-jr's Avatar
https://ls1tech.com/forums/generatio...fo-inside.html
Old Jan 21, 2009 | 10:24 AM
Jimbo'sZO6's Avatar
I did that on mine because of the same problem with the header, it worked out just fine. Go for it!
Jimbo
Old Jan 21, 2009 | 10:31 AM
99blancoSS's Avatar
If someone needs harness extensions I have them in stock for a conversion from an LS1 to LS2
Old Jan 21, 2009 | 02:33 PM
DBRODS's Avatar
thanks guys I appreciate it, I was pretty sure it would work, but wanted a comfirmation to just make sure..
Old Jan 22, 2009 | 05:02 AM
WKMCD's Avatar
Jimbo
I did also. No problem!
