ls2 oil presser sensor
Old Jan 20, 2009 | 09:58 AM
Big Bird WS6's Avatar
Default ls2 oil presser sensor
i am putting an ls2/ls3 in my ls1 car. will the ls2 sensor work with my PCM. if not what do i do?
i am using an ls2 valley cover.
Old Jan 20, 2009 | 10:08 AM
the_merv's Avatar
Would that be the smaller Oil Press. Sensor like in the Trucks, and it uses the Connectors like on the TPS?
Old Jan 20, 2009 | 10:11 AM
yes it is smaller. i guess it also has a temp sensor built into it. how do i get this to work?
how do all you guys get the ls1 to ls2 to work
Old Jan 20, 2009 | 10:37 AM
the_merv's Avatar
I've never heard of it having a Temp Sensor built into it, unless that is for Oil Temp..
I figure the middle wire would be your signal wire like the single one on the LS1 Harnesses, but I could be wrong.
I hope someone has some insight to this as well, cause I would like to know.
Old Jan 20, 2009 | 02:55 PM
silverLSWON's Avatar
just bolt the stock ls1 oil sender in the ls2 valley cover. it's works fine, just sits a little higher up
Old Jan 20, 2009 | 03:33 PM
the_merv's Avatar
May be a little too high. Atleast you can't break the Truck ones as easily..
Old Jan 20, 2009 | 03:37 PM
threads are different. i wish it was that easy. i might just have to tap it and make it work.
Old Jan 21, 2009 | 12:18 PM
1sick'98WS6's Avatar
There shouldnt be tapping neccessary, but this is an ls3... I was scratching my head until I just swapped the sensor and it fits perfect
Old Jan 21, 2009 | 12:25 PM
the_merv's Avatar
I thought they were the same Threads too..
I would check it again, maybe you started it crooked or something.
Old Jan 21, 2009 | 12:48 PM
so just buy the ls1 sensor and see if it works? it looks so much bigger. but ok
Old Jan 21, 2009 | 12:57 PM
the_merv's Avatar
I know the ones from a Truck are small..
Old Jan 21, 2009 | 02:46 PM
It is much bigger, and the raised part of the valley cover only makes it taller. It looks goofy but it works. I called TSP about this when I was dealing with it, they said it is a direct swap
Old Jan 21, 2009 | 02:57 PM
the ls1 f-body sensor threaded right into the ls2 valley cover with no problems. it just sits about an 1 1 1/2 inch higher and looks funky but it clears the cowl panel just fine.
Old Jan 21, 2009 | 04:39 PM
^ ^ ^ if it is that much taller. can i cut it down?
Old Jan 21, 2009 | 06:03 PM
Detroitmuscle's Avatar
I wouldn't suggest cutting it, your talking about cutting a sensor lol
Old Jan 22, 2009 | 08:09 AM
^ ^ ^ no :LOL: the port on the valley cover
Old Jan 22, 2009 | 12:26 PM
no do not cut it down, it's actually better that way IMO. you can see the sensor easier when you pull the intake off so you have a less chance of breaking it like some people do. also its easier to change out the sensor if it goes bad.
Old Jan 22, 2009 | 12:52 PM
^ ^ ^ googd call.
thanks guys.
