N/A 434 LSX Build
Old Apr 24, 2009 | 06:46 PM
  #81
99blancoSS's Avatar
looking good
Old Apr 24, 2009 | 07:20 PM
  #82
3.8redbird's Avatar
I love you
no homo
that is some beautiful **** man
Old Apr 24, 2009 | 07:22 PM
  #83
Haans249's Avatar
Originally Posted by 99blancoSS
looking good
Thanks!
Originally Posted by 3.8redbird
I love you
no homo
Hahaha, no problem. Thanks for the compliment. Other than the redneck exhaust, i certainly like it
Old Apr 24, 2009 | 09:13 PM
  #84
KCS's Avatar
KCS
Moderator
Originally Posted by Haans249
Ah, good point. If I remember correctly though, the plate is not that thick, so i'm not sure if that can be done. But if you have done it yourself, then obviously, yes!
Yes sir, I've done it many times and seems to work well.
Old Apr 25, 2009 | 12:53 AM
  #85
Haans249's Avatar
Well, need a JP double roller? haha.
Old Apr 25, 2009 | 10:25 AM
  #86
KCS's Avatar
KCS
Moderator
Haha, no I'm good, thanks.
Old May 21, 2009 | 03:11 PM
  #87
PUNISHER TA's Avatar
Hows the car? Running good. Any problems?
Old May 21, 2009 | 03:26 PM
  #88
Stang's Bane's Avatar
I know you have probably already said, but what valve springs?? I noticed the beehives..
1518 PAC's???
Old May 22, 2009 | 12:55 AM
  #89
Haans249's Avatar
Car is running great! I have about 2k miles on the motor, its really tearing it up. Driveability is MUCH better than before, and it is definitely making more power. I took it to Stenod for a dyno session. Made 451hp and 400 rwtrq through my crappy exhaust/9"/heavy rims/tires. Numbers appear low, but they aren't, I assure you For comparison's sake, they had a C6Z06 ported heads/cam/intake make 450hp on the same dyno even though it has lighter internals/better exhaust/lighter drivetrain/ported heads/intake. I don't know what cam it had in it.
The topper: we uncapped my cutout, untuned (only paid for 3 dyno pulls) and running near 14:1 AFR through most of the run it netted an additional ~30hp and ~25ftlbs through the whole pull. We cut the run at 4K rpms and it was ALREADY making 451 hp at 14:1 AFR haha. Spark is set at 30degrees AFR at 12.8-13.1:1. Amazingly, no detonation.
I also went to Test and Tune last night at Milan, only got two passes in, first pass just puddling through the gears ran 12.6 at 117mph, 2.4 60ft. Second pass, spun for nearly 100 ft, and had to pedal first till I got traction, then I hit the rev-limiter lol. Ran a 12.7 at 122mph (shifted a little quicker) 2.7 60ft. On street tires ~3800lb race weight, so its a pig. I also severely need the !Driver mod haha.
I'll have the video uploaded soon.
1518 PAC's???
PSI LS1511 Max Life Springs with Katech Retainers. Probably one of the best spring/retainer combinations you can get for the LS7 heads. The retainer alone only weighs 5 grams. 1.85" install height, coil bind at 1.10", max lift .700".
Attached Thumbnails N/A 434 LSX Build-img_0647.jpg
Old May 22, 2009 | 03:13 AM
  #90
Thats sweet dude.
Let me know, next time youre heading out to Milan. Ill head down there.
Lets see that video
