LS2 into WS6
Old Feb 20, 2009 | 09:08 AM
PONTIAC SLP's Avatar
Default LS2 into WS6
Hi guys , in few days i'll buy LS2 complete engine it's ready to run and i'll install it into my WS6 , so what i need to complete this setup ?
Old Feb 20, 2009 | 12:35 PM
1sick'98WS6's Avatar
By ready to install what do you mean? Ls2 uses different valley cover, cam position sensor, knock sensors need to be relocated, and it has to have the 24X reluctor on the crank.
Old Feb 20, 2009 | 12:54 PM
purple95ta's Avatar
whats the reason for the swap? did you blow up you'r Ls1?
Old Feb 20, 2009 | 01:01 PM
Disturbed Bird's Avatar
probably b/c it allows for bigger cubes.
Old Feb 20, 2009 | 01:17 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Some LS2s were 24x....you need to make sure. As far as what all else is needed....there is a knock/cam sensor harness extension available.
$59.95 from us.
Then a cable driven TB with a bracket for the cable.
If it is a 58x engine, just use the Lingenfelter 24x to 58x adapter, its around $300.
That is pretty much it, except you need to change the oil pan/dipstick/pickup to the F body style.
Old Feb 22, 2009 | 08:21 AM
General Jack's Avatar
Check out this thread...
https://ls1tech.com/forums/generatio...body-help.html
