LS3 Bare Block Completion Kit part numbers and prices
Part # Qty Part Description
12599296 1 Valley Cover w/ bolts, seals, gasket and pcv baffle
GM PART # 12599296
OUR PRICE: $71.90
12599298 1 PCV Tube
GM PART # 12599298
OUR PRICE: $5.47
12600325 1 Front Cover w/ Cam Sensor, Seal, Bolts & Gasket
GM PART # 12600325
OUR PRICE: $68.49
12602548 1 Coolant Crossover Pipe
GM PART # 12602548
OUR PRICE: $21.25
12602540 2 Coolant Caps
GM PART # 12602540
OUR PRICE: $4.95 x 2 = $9.90
11588714 4 Coolant Pipe/Cap Bolts
GM PART # 11588714
OUR PRICE: $2.64 x 4 = $10.56
12615666 1 Rear Crannkshaft Seal Housing
GM PART # 12615666
OUR PRICE: $39.68
12574293 1 Rear Crankshaft Seal Housing Gasket
GM PART # 12574293
OUR PRICE: $14.86
11515758 12 Rear Crankshaft Seal Housing Bolts
GM PART # 11515758
OUR PRICE: $0.45 x 12 = $5.40
89060436 1 Rear Crankshaft Seal
GM PART # 89060436
OUR PRICE: $13.51
12573460 1 Oil Galley Rear Plug w/ Seal
GM PART # 12573460
OUR PRICE: $4.39
11588949 2 Oil Plug Side
GM PART # 11588949
OUR PRICE: $4.71 x 2 = $9.42
9427693 4 Water Drain Plug Frt
GM PART # 9427693
1453658 2 Transmission Dowel
GM PART # 1453658
OUR PRICE: $2.57 x 2 = $5.14
11609289 1 Water Drain Plug - Hex
GM PART # 11609289
OUR PRICE: $7.59
12589016 1 Camshaft Retainer Plate
GM PART # 12589016
OUR PRICE: $13.63
11561455 4 Camshaft Retainer Plate Bolt
GM PART # 11561455
OUR PRICE: $2.16 x 4 = $8.64
12570125 2 Knock sensor
GM PART # 12570125
OUR PRICE: $8.08 x 2 = $16.16
12585546 1 Crankshaft Position Sensor
GM PART # 12585546
OUR PRICE: $28.75
11515756 1 Crankshaft Position Sensor Bolt
GM PART # 11515756
OUR PRICE: $0.45
12591689 1 Cam Gear
GM PART # 12591689
OUR PRICE: $15.26
11561283 1 Cam Gear Bolt
GM PART # 11561283
OUR PRICE: $2.08
12556582 1 Crank Gear
GM PART # 12556582
OUR PRICE: $19.76
12586482 1 Timing Chain
GM PART # 12586482
OUR PRICE: $32.05
12588670 1 Timing Chain Dampener/Slide w/Bolts
GM PART # 12588670
OUR PRICE: $11.55
12601402 1 Balancer Balancer - 6.0 liter - 6.0 liter
06-08 $119.80 $71.02
12557840 1 Balancer Bolt
GM PART # 12557840
OUR PRICE: $3.20
12595365 4 Valve Lifter Guides
GM PART # 12595365
OUR PRICE: $5.56 x 4 = $22.24
12551163 4 Valve Lifter Guides Bolts
GM PART # 12551163
OUR PRICE: $1.53 x 4 = $6.12
total $549.03
just thought some one might need this as reference.
GM PART # 12599296
OUR PRICE: $71.90
12599298 1 PCV Tube
GM PART # 12599298
OUR PRICE: $5.47
GM PART # 12600325
OUR PRICE: $68.49
GM PART # 12602548
OUR PRICE: $21.25
GM PART # 12602540
GM PART # 11588714
GM PART # 12615666
OUR PRICE: $39.68
GM PART # 12574293
OUR PRICE: $14.86
GM PART # 11515758
GM PART # 89060436
OUR PRICE: $13.51
GM PART # 12573460
OUR PRICE: $4.39
GM PART # 11588949
GM PART # 9427693
GM PART # 1453658
GM PART # 11609289
OUR PRICE: $7.59
GM PART # 12589016
OUR PRICE: $13.63
GM PART # 11561455
GM PART # 12570125
GM PART # 12585546
OUR PRICE: $28.75
GM PART # 11515756
OUR PRICE: $0.45
12591689 1 Cam Gear
GM PART # 12591689
OUR PRICE: $15.26
GM PART # 11561283
OUR PRICE: $2.08
GM PART # 12556582
OUR PRICE: $19.76
GM PART # 12586482
OUR PRICE: $32.05
GM PART # 12588670
OUR PRICE: $11.55
GM PART # 12557840
OUR PRICE: $3.20
GM PART # 12595365
GM PART # 12551163
total $549.03
LS1Tech Sponsor
Well, you get most of those parts (all the plugs and dowels including trans and cyl head) when you order our kit....
PN is SDLSPK....scoggin dickey LS Plug Kit. How simple is that?
$74.95. We take care of most of the work for you. And it seems you forgot a few things as well, like the coolant cap gaskets. and maybe balancer bolt.
Really most of the parts are the same from all the LS engines
Just another FYI in the thread
Well I did try to help some members with some actual part numbers. The balancer bolt was in there also.
GM PART # 12557840
OUR PRICE: $3.20
it was in there
dosen't the coolant cap come with the gaskets.
GM PART # 12557840
OUR PRICE: $3.20
it was in there
It says "No results found search for SDLSPK"
