L 92 engine mod. questions
Old Mar 12, 2009 | 05:13 PM
jim copland's Avatar
Default L 92 engine mod. questions
I have a new L92 and wish to make some mods. including a non vvt cam and need to include a means for a cam sensor on the timing cover. I believe that I need a component or two to do away with the vvt and also don't know if I can use the existing lifters. I am aware that the vvt is potentially a good thing but for my application not needed . Thanks in advance for input. JC
Old Mar 12, 2009 | 05:18 PM
shoemike's Avatar
What are you putting it in?
Old Mar 12, 2009 | 05:56 PM
WKMCD's Avatar
The lifters have to go. IIRC you will want to replace the oil pump also.
Old Mar 12, 2009 | 08:48 PM
It's going in a 33 hot rod, kit car from Factory Five, with a tremic TKO 600 trans
Old Mar 12, 2009 | 08:51 PM
Ramairbird's Avatar
See the sticky in this forum, tons of info about l92 swaps.
Old Mar 12, 2009 | 10:16 PM
SweetS10V8's Avatar
VVT potentially good???? VVT is awesome, peak torque and power everywhere. No losses anymore. I just cant understand everyone wants to be stuck back in the days of the small block chevy....
Now Active fuel management(AFM) that can go, heavy lifters and wont take over .500 lift when deactivated. So you basically cant do a cam with AFM.
Old Mar 12, 2009 | 11:43 PM
org's Avatar
org
Why is that? It's not DOD is it?
Old Mar 13, 2009 | 09:25 PM
SweetS10V8's Avatar
AFM is GMs term for DOD, yes.
Its just how the lifters are designed.
Old Mar 14, 2009 | 06:20 AM
org's Avatar
org
Does it have AFM though? He only mentioned VVT...
Old Mar 15, 2009 | 08:11 PM
95 Black Mamba's Avatar
If you only have vvt you can use your lifters,to go with non vvt cam you have to change the timing cover, timing chain you can get a cover for like 90 bucks with cam sensor through scoggin dickie.
