Which heads for a 454 lsx drag race setup?
Old Mar 12, 2009 | 06:50 PM
TurboAv's Avatar
Default Which heads for a 454 lsx drag race setup?
I've been thinking it would be cheaper to build a monster stoker than go the turbo route. So that being said I want to build a 454, run a single plane intake with a 4bbl throttle body, and a solid roller cam. This is all going in a heavy GTO with a TH400 4000-5000 stall. I want to be able to rev it to 7k also.
What heads should I choose?
Old Mar 12, 2009 | 07:10 PM
CorvetteMajor's Avatar
7 Second/200 MPH Club
Just buy my engine and save your self a ton of time and money. Nothing is better then a turbo setup.
Old Mar 12, 2009 | 07:32 PM
Shawn @ VA Speed's Avatar
At a minimum you should run an ls7 style head either Performance inductions or all pro,the best would be a c5r head
Old Mar 12, 2009 | 08:24 PM
Haans249's Avatar
Good point. TIME being the greater savings of the two. It would take near a year to replicate your setup.
Old Mar 13, 2009 | 12:16 AM
TurboAv's Avatar
What about the PRC LS7 heads?
Old Mar 13, 2009 | 12:22 AM
LS6427's Avatar
Do what I'm doing with my 454ci, waiting for the new Edelbrocks to come out. You'll need way over 400 cfm heads to feed an N/A 454ci anywhere near its max flow potential.
But if you can't wait, ported LS7's are good for N/A, if you're gonna spray it use the thicker deck heads by ET or All-Pro.
Old Mar 13, 2009 | 12:42 AM
Gordon0652's Avatar
Canned Valve Heads! lol
Try TSP LS7x 280cc.
Old Mar 13, 2009 | 12:43 AM
Gordon0652's Avatar
Do a turbo or SC.
Something like a LSX 434 with twin 80mms.
Old Mar 13, 2009 | 01:23 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
Wcch All Pro lsw head, in my experience they are great!!
Old Mar 13, 2009 | 01:59 AM
99blancoSS's Avatar
^^^^ Here is a set in action, check out how small the cam is in this combo for a 427 CID
https://ls1tech.com/forums/dynamomet...6-results.html
Old Mar 16, 2009 | 01:24 AM
kmracer's Avatar
dont let anyone talk you out of a bad *** all motor setup!
