ls2 to ls3?
Besides the pistons should everything just be a direct swap? Im thinking i only need to buy new pistons and the bare block? crank, rods, cam, water pump, oil pump, exc should move right over?
not sure if I will have any issue using a crank with a 24x reluctor wheel. I'm moving the ls2 cps to the ls3 block.
going to run it w/ 317 heads also. not changing the heads and intake.
The CPS will fit in the same spot whether or not it's black(24x) or grey(58x). Since you have a 24x car you'll want to swap it over for sure, as well as the 2x cam sensor and cam gear.
One more thing: for a GTO, you'll have to plug the dipstick hole in the block, too.
