Cam for L92 Heads: Lessons Learned
He does have some good points and information but there is always more than one way to build something and other points of view that people should look into as well.
Some will say the LS7 cam has slightly lower lift .558 vs .600+ for the Lingenfelter but for long term durability lifts of .550 or less are easier on the stock rockers and valve guides according to Page 73 of the new Motorbooks "How to Build and Modify GM LS Engines". http://cgi.ebay.com/ebaymotors/How-t...item27ac147c3d
His reasoning is obvious fast cyl filling, you can still use plenty of overlap like this with a tight lsa as with short intake duration you minimise reversion and the intake moves a LOT of air thru a short duration intake. Eg 224 intake with 650ish lift or late 220s for a stroker with generous ex lift prostock style, try this with a 240s intake lobe and u lose low end for a minimal top end gain. The cam has have lobes in this scenario to work.
Eg 230s 250s cam huge splits on 114 LSA u get much more overlap and potential to lose power from increased reversion. With a smaller intake u can get away with it more and actually benefit if the events are right.
To go 230s why are people always speccing 230-248 when a 230-234 will make the same power. I think a 230s ex is well capable of moving 600hp of air. Intake reversion is a killer for torque and if the same power results can be obtained from a small split as big split with much less overlap why are ppl still doing it?
If I had a stroker I would look at less intake duration and more lift. And still dont go crazy with ex duration.
I have a cheater cam I used with my blown setup and made 30hp more at the wheels with 1 psi more boost. It drove very well had a lot of torque and revved pretty hard. They do work good They dont really need a lot of overlap the intake doesnt open to like 10 deg ATDC@ 50thou lift so it pulls a vacuum thru the intake from late ICL and then have massive lift and short acting duration and a 230 ex valve they are proven to work IMO the best street cam for these heads for smooth power.
For more top end hp good cam(if ur not worried about lift) is the 224xfi 230xer ex paul used the 224-228 xer to get the record in his G8
For excellent topend spins 230xfi234xer on 114.
For ex bottom end in a 6L-6.2 I like the 218-224-112xfi cam+0 it holds on and feels very abrupt any cathedral head car ive driven doesnt come close to the aggro power delivery of this cam and heads it may hold on better with a 228 xer zorst. The whole big port lazy down low isnt true they just need a shorter duartion intake then norm.
I guess for a stroker u could go crazier and use a 228 on 650 lift and 230s ex on 112 for the same effect.
Spin proved that small splits work with LS3s making over 500. And I see it here all the time.
We are posing over the LS3 cam testing and seeing 550hp. Livernois did a L92 swap on LS2 and it made 546hp with L76 intake and 494ftlb with a 232 236 112 cam at 3000rpm it makes 406 tq. This is comparable to the LS3s but with tighter split and lsa. With the GMPP it made 454 tq and peaked the sam hp much later, it really needs a tighter lsa like 108 to get it back.
Carcraft then did a LQ4- L92 head swap with a old comp off the shelf cam the classic 228-230-112 .571 lift on xe lobes.
With the GMPP intake it makes 551rwhp and 464 tq at the same rpms as the previous test engine with gmpp. This cam makes more power by 5hp and 10 foot pound more torque with less cam. Add 40 odd tq for the loss of the single plain and again we see a 550/500 6L with stock heads and intake with a traditional cam with lift that is comparable to the cams that did well in the LS3.
http://www.carcraft.com/techarticles...comp_cams.html
http://www.gmhightechperformance.com...ads/specs.html
So unless u are trying to win engine masters challenge with topshelf manifolds and heads and tight lsa roller cams maybe a 230 traditional cam is fine.
Thanks for the info. I believe these are flywheel numbers and not rwhp numbers though. 550fwhp might be 450-480 at the rear tires.
Thanks
Thanks
Thanks
