Cam for L92 Heads: Lessons Learned
A 500rwhp on dynojet would read around 330rwkw at the most on a mainline. Even then maybe less.
Infact a 233 233 112+0 cam is making 350rwkw with fast and higgins heads. and over the radiator intake with speed density tuning. 350/.746 this is 469hp plus the 10% loss takes it to 521rw dynojet hp, around 580-590 flywheel hp..
A stock LS3 on mainline will make around 335 on a DJ around 382 both M6. Thats a 12% loss. It is hard to compare but all the results are consistent with a percentage difference.
This is another eg that single patterns work well on the short strokes,
2+ yrs later, looks like he knew what he was talking about..
Comp LS1 Custom 218/228 .563/.571 112º + 0
http://www.gmhightechperformance.com.../photo_11.html
cheers
Valve events are still the same as if it were a 4.0l V8 or a 7 litre motor so providing the heads work well and they do, cylinder fill should still be the same. It seems to me that lsa, Icl and overlap characteristics are more important than lift. The stock ls7 cam is a 210 intake duration and works pretty good so an extra 8* should fill the pots pretty well IMHO.
cheers
If you click the youtube link in sig there is a pass running 118.7 mph @ 11.8 on stock stall .... not bad for an almost 4000lb car. I have yet to see a VE/G8 6.0L A6 run an 11 with a stock stall N/A on pump fuel. I know there is plenty with bigger cams running 12's.
cheers
Good luck with cracking 11.5 that would be quite an achievement on motor in a G8.
cheers
cheers
I think I am going to blow away everyone on the entire internet, in every automotive forum, and in every "what’s the best cam for this engine" topic. Are you ready? Here we go.
When selecting a cam you must NOT think how this camshaft and engine is going to propel this vehicle.
You have to think HOW IS THIS VEHICLE/COMBO GOING TO LOAD THIS ENGINE. And then decide factors like lobe sep. And rpm range your shooting for.
Cylinder head design and flow will dictate valve overlap requirement. That gmhightechperformance article is more proof that one thing we do know is that these L92/L76 heads with large intake valves and big difference in int to exh flow really like low to no valve overlap. But if you look at LS1/6 cathedral heads with smaller valves, intake ports, and not so different int to exh flow numbers, they like a little more overlap.
Engine dynos numbers are not a good indication of what you need for your particular combo. Dynos load the engine the exact same way every run. It may show more torque output, but that doesn’t mean you will go faster in the 1/4 mile. Many factors will change how the engine is loaded (or how easy of a job it has to do). Dynos are good for looking at where peak torque will occur and where the placement of torque will be.
Everybody see's this cam-x in a 2800 lsx drag car run 9's and they think they should use it in a 4000 LB GTO with a similar engine. It will work good but not great.
After extensive research and watching other people spend money trying different cams you start to see a trend.
My opinion (not fact) is heavy vehicle, stock gearing, stock or mild converter and you will need the 224/230'ish with a wide 114 to 116 or higher lsa cam.
Lighter vehicle, high stall, aftermarket gearing and heavy mods and you will need 110- 113 lsa. Look at like this. The more work your engine needs to do to, the more lsa you should run.
Years ago, in an article in some magazine, John Lingenfelter said “make as much torque at your shift recovery rpm and your car will go faster” I have tried this and it works. Some of these tight lsa cams loose too much torque in lower ranges and only squeak out a touch more power up top. Not worth it to me. This article (I will try to find it and post the actual numbers) showed a typical pass down the ¼ mile in a 12 second car and plotted rpm against time and showed how little time the engine spent at top rpm. The difference in amount of time spent in the lower rpm ranges compared to high rpms was a real eye opener. I really feel that the single most important thing about cams in these L92 heads is keep valve overlap low and use engine load to determine the lsa.
My favorite is a fairly small grind 224/236 117+2. With just over .600" lift, this cam drives and idles like stock but picked up nearly 100 RWHP in a L99 Camaro. 313 stock vs. 410 w/cam and headers. This was through the stock airbox as well. We did the same cam in an LS3 Camaro and did 438. I designed the cam for F/I but was pleasantly suprised with it's NA peformance. The car did 570 with the Procharger but was limited to 5500RPM for lack of fuel... (twin pumps on the way)
The larger of the two is a 231/247 113. This cam has a nice lope and drives well. It did 469 cam only and IMHO make a great daily driver for someone looking for a cam with a nice aggressive idle. One of my customers just finished an LS3 H/C project with this cam and a set of Thunder/GTP LS3 heads. That car did 515 to the wheels. There is a dyno graph of the cam only car in the dyno section and I will be posting cam only graphs of the 224/236 117 shortly.
I thought I'd just share our experiences here.
Thanks,
Shane
NOW . lets talk about low lift cams.... i have a 230-242 .600 on a 110...truck made 458 and 435 with limited fuel syatem.... well im lookin for something else...
i was thinking about a 218-230 .550 lift on a 115 lsa..
let the opinions fly.
im at this point im not lookin to make high hp .no harsh ramp rates. just a nice tourque curve with great street manners,
I have a 227/235 .614”/.621” 113LSA +4 advance spec'd out for my PRC LS3 heads w/ 66 cc chambers, 0.40" gaskets and an lq4 bottom end (will need to fly cut) its on LSL lobes.
we'll see what it does...what do you guys think?
Chad
