More L92 aircraft
The engine won’t be operated like a car engine, but will be more like a boat…a short period of wide open throttle with a RPM limited to around 4800, then 10 minutes or so at WOT and 4000, followed by up to a couple of hours at around 3500 for cruise, making 200 to 220 HP or so for cruise at altitude.
The only thing really different from a car or boat installation is that the exhaust will consist of 8 identical stacks of 14” length instead of conventional headers and pipes. I’d appreciate any opinions on what effect this will have and what cam specs (in general) will be best for this exhaust.
I’ll be using (probably) a SD setup of either a GMPP controller or a Megasquirt, since it seems O2 sensors won’t work with short stacks.
I have the L92 and a 6.0 LQ4 (both new) and also wonder if the LQ4 heads might be better than the L92 heads for the maximum power (torque) between 3000 and 5000 rpm. Any opinions will be welcome here, too.
To clarify: I don’t care about power above 5000 rpm. For this installation it doesn’t exist and is unusable due to propeller limitations. I don’t really need a particularly smooth idle below about 1000 rpm. Throttle response off idle isn’t important except that the engine needs to smoothly accelerate into the 3000+ range. I don’t want to change anything but the cam and oil pan, and possibly swap the heads if it makes sense.
I’ve always gotten some good information in other discussions, so thanks in advance for your thoughts.
Good luck,
Richard
You're correct about the LQ4 block, it is iron. I'll be using the L92 short block regardless of which heads I end up with, it's aluminum. Anything over 200 hp for takeoff will do the job an the airframe will take up to 450 or so. I'm shooting for 350+ for takeoff and 200 + for cruise. Since cruise will be at around 8000+ feet the power will drop off about 25 per cent. The L92 should do the job, power wise. The cowling is only about 27" wide, so no room for exhausts. My drive uses a 3" chain.
Should work out just fine. Jim Rahm built them for Lancair, he's a retired General Motors engine designer.
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 212/218
Gross Valve Lift (Int/Exh): .531/.531
LSA/ICL: 113/109
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1600-6400
What do you think? Would reducing the LSA to 110 help with the short stacks? This grind looks like it fits other than the LSA. I'll be running pump gas mostly, but once in a while I'll probably have to use some 100/LL Avgas (another reason for no O2 sensors.) I assume no problems with valve/piston clearance with the stock L92 engine(?)
...........Lobe #.........Adv Dur.........@.050"............@.200".............l ift w/1.7rr
Both I&E 3301...........266º..............214º............. .129º................. .519"
With the straight exhaust you don't need the extra scavenging of a longer exhaust lobe.
Also I would suggest replacing the factory valves with stainless units. I don't feel the oem valves are aircraft worthy. There have been a number of oem valve failures near the valve lock groove.
Richard
I would add that VERY few folks have optimized cams for an LS engine running the rpm/power bands you need, especially with 14" exhaust stacks. Individual stacks are not a bad idea, BTW. The correct cam can be designed to complement your constraints.
I suggest that the optimum cam probably won't be on someone's shelf, unless perhaps it's one of the many OEM cams! I would also use the best endurance springs I could find running at a fairly low stress level. PAC nitrided springs "spring" to mind.
IMO, you really should get with an LS valvetrain specialist. You might be surprised how mild that optimum shaft might turn out.
Good luck.
Jon
Stock cam and springs sound good to me at the rpm levels you're considering. They'll last a long time and remove that as an issue to worry about. About the last thing you want is an "unscheduled" landing due to valve train trouble.
A video of this beast once finished is necessary.
