Harland Sharp LS7 Part # SLS78A
The part # for the H S rollers for the LS7 2006 > present is SLS78A
If no resellers list them, contact HS direct @
http://www.harlandsharp.com/contact.htm
I had to use SDPC valve cover spacers and had to shave off the corners a lilttle so they'd fit o-k. Other than that, no problems with em.
They mount on the exsisting pedistal on the LS7 heads so no shaft system required.
