Good ole TuskeyZ!!!!
Example:
http://www.yellowbullet.com/forum/sh...d.php?t=321654
And these seem to look like Rowdy Yates heads, flow numbers look Nearly Exact to what Darin M. sent.
https://ls1tech.com/forums/dynamomet...ore-c5z06.html
Funniest thing the engines pretty much spec’ed did that around 6 yrs ago if I ever where to get a big bore block. 4 inch crank or 4.125 is the only?
Got in touch with FRH about seeing which port program we could use with the spare head. Spoke with Martin and said he’d talk to Chris..told Martin to refer to me as the guy who had Chris Bennett verify everything and send numerous customers. Just gotta find time. It’s something cheap enough to do as I’ve got other irons in the fire. But $1800 for Ls7 heads is a fact. We talked $ might be cheaper with my references....may see if a 2.230 - 2.250 valve fits on GP. Port work is only $1100 just gotta find a program the heads like and I like. When I find time I’ll have Jim send the spare to see.
no problem brother! I got your back.
How wrong we were.
