Dyno Results -RPM-Motors Small Bore LS7 heads on a 4.005 Bore - C5Z06
TSP 402 short block 11.1:1
Eagle Crank/Rods/Diamond -15cc pistons/ARP everything
RPM small bore CNC LS7 heads. 60cc
RPM Ported LS7 Intake/ 96mm NW Throttle body
236-248 .648/651 114lsa
ARH 1 7/8 headers no cats.
powerbond ud pulley
diamond stage 2 clutch/ Light flywheel
ls7 rail/injectors
ls7 rockers trunion upgrade
Halltech air intake
Evans Water pump
This is our first test on the 4.00 bore - clearly, we can cam this up some if we want to. In the meantime it drives beautifully, idles like a champ and has a great torque curve.
![](http://i74.photobucket.com/albums/i254/H8LAPD/dans-1.png)
First Warm Startup:
http://www.youtube.com/watch?v=2E56w...layer_embedded
Dyno Run:
http://www.youtube.com/watch?v=9efkY...layer_embedded
Old Motor Out:
![](https://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc7/402025_365842586764846_100000173229773_1770281_1632686584_n.jpg)
New Shortblock:
![](https://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/407817_365843443431427_100000173229773_1770284_1276883977_n.jpg)
![](https://sphotos.xx.fbcdn.net/hphotos-snc7/399754_365843906764714_100000173229773_1770289_1597303136_n.jpg)
New Small Bore LS7 Heads:
![](https://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc7/396170_365844083431363_100000173229773_1770291_361361542_n.jpg)
![](https://sphotos.xx.fbcdn.net/hphotos-ash4/401337_365844150098023_100000173229773_1770292_1030789354_n.jpg)
![](https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/405838_365844236764681_100000173229773_1770294_2076002537_n.jpg)
![](https://sphotos.xx.fbcdn.net/hphotos-snc7/398680_365844286764676_100000173229773_1770295_1457652919_n.jpg)
RPM Ported LS7 Manifold:
![](https://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/395010_365845623431209_100000173229773_1770300_946913161_n.jpg)
If you bumped this motor to 11.7:1 it would have been kissing 550/500. Also this cam is very mild and we may end up putting something larger in and see what she does.
These heads are a amazing piece of work and a great option for us 4.0 bore and up guys.
This is the car:
![](https://sphotos.xx.fbcdn.net/hphotos-snc6/184974_207240639291709_100000173229773_964382_2201773_n.jpg)
![](https://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc6/183505_207240482625058_100000173229773_964377_6443616_n.jpg)
powerbond ud pulley
ls7 rail/injectors
Halltech air intake
Evans Water pump
First Warm Startup:
Dyno Run:
Old Motor Out:
New Shortblock:
This is the car:
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/150503_178128688869571_100000173229773_706282_5156593_n.jpg)
I you were to run these on say an ls3 bore they would be slightly different then these which are for the LS2. Should have no problem running these on that bore. They are designed for a 4.0 bore or larger.
I am curious about flow numbers for the heads ... were they bench tested. I would like to compare them to my TF215's. I like the thought of a larger head/intake/TB combo, but I don't want to lose any torque. That is the best part of my motor.
You can see they make torque. They flowed 383cfm at .700 on my set of heads. Also my torque would have made 500 with a bit more compression. But due to the block having the -15cc dished piston we ended with just over 11:1 my fault for buying a used block. Was too good a deal to pass up. You will want to run a different cam with these heads then one cut for cathedral port heads.
These were some flow numbers from a prior set to mine.
Intake Flow (on 4.040 Bore)
.1 = 71
.2 = 164
.3 = 246
.4 = 301
.5 = 338
.6 = 364
.7 = 378
Exhaust Flow (on 4.040 Bore)
.1 = 56
.2 = 116
.3 = 178
.4 = 221
.5 = 240
.6 = 250
.7 = 256
I was going to run my old top end at first. But was excited to be the first to try these heads out. So i sold my topend to cover the cost of this setup. almost was a wash as you can get an ls7 intake on the cheap!
Old setup:
TEA TFS 220's
SPin Ported fast 92/96mm NW
YT rockers
svo 42's
.1 = 71
.2 = 164
.3 = 246
.4 = 301
.5 = 338
.6 = 364
.7 = 378
.1 = 56
.2 = 116
.3 = 178
.4 = 221
.5 = 240
.6 = 250
.7 = 256
Old setup:
TEA TFS 220's
YT rockers
svo 42's
.1 = 71
.2 = 164
.3 = 246
.4 = 301
.5 = 338
.6 = 364
.7 = 378
.1 = 56
.2 = 116
.3 = 178
.4 = 221
.5 = 240
.6 = 250
.7 = 256
.1 = 71
.2 = 164
.3 = 246
.4 = 301
.5 = 338
.6 = 364
.7 = 378
.1 = 56
.2 = 116
.3 = 178
.4 = 221
.5 = 240
.6 = 250
.7 = 256
By the way my TFS flow's are ...
0.100... 59.6... 68.3
0.200...121.9...139.8
0.300...186.7...218.5
0.400...231.4...270.9
0.500...254.2...304.3
0.550...260.2...314.8
0.600...266.1...321.8
I actually got to look over a large bore casting beside a factory ls7 head. The oe ls7 head has a bulge behind the intake valve thats protrudes out. They designed these to where the coolant passage wouldn't stick out. With these, you have a much straighter path from the runner to the chamber that's actually smaller in size but flows considerably better. I look forward to many more great results with these heads. Great job RPM!
My combo is a modest combo on 91 pump and it made some serious strong numbers! But again I drive my car often and wanted a more mild mannered car. I got what I wanted as this drives as nice as my 228-232 combo did on my stock shortblock.
Old setup:
TEA TFS 220's
YT rockers
svo 42's
Old setup:
TEA TFS 220's
YT rockers
svo 42's
I think we will see some insane numbers from these heads in the future. Like I said build my combo to closer to 12-1 with a thumper cam and I bet you could see upwards of 560-570whp and 510-515tq on pump gas. Add a ported LS7 Fast 102/102 into the mix maybe closer to the magic 600whp mark who knows. Hell I'm a cam swap away from 550whp right now.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
So what numbers did this combo make??? What were the increases from all of this work? I presume these mods were on a stock block LS6?
Nice peak horsepower, but I am waiting to see what it takes to bring the torque up too. The posts I have seen indicate the 102/102's dropping torque. Your 402 may make a good test bed for my future 402 mods.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Yes those mods were on my stock block and went 450/412 on the same dyno.
Bring the torque up? I have a great torque curve. Especially when you look at my mild compression 11-1. I would imagine at 12-1 itwould pick ap 10-15 torque everywhere.
I didn't mean to imply that you were NOT making good torque. My meaning was that, in my case, before I run out and go to a 102/102/rectangular port setup, I would want to see a combo where the rwt was higher than your 488, since I am already at 497, but with 30 less rwhp. I would have to justify it to myself. Don't think I am to trying to down-play your accomplishment and if you read it that way, it was not my meaning .... damn forums. It is easy to read into something or hard to express a meaning on "paper".
Its all good. I believe you could do my exact combo with higher compression and go 550/505 easy. Especially on better then our crappy gas here. Also basically you could sell your combo to pay for this combo no problem. Not quite if you go with a Fast 102 though.
Now that would be something to think about next winter. Currently, I am running 11.6:1 with total timing of 24* and air fuel of 12.8:1. and we do have 93 octane readily available here.
